silicone vac. line vs. standard rubber
what would be the benefit of using silicone line for the boost controller vs the standard rubber stuff....i have a lot silicone line but i just used the rubber stuff instead...should i change it or it doesn't really matter.....also should one line of the boost controller be a smaller diameter than the other.....?
I had to use silicon tubing for my wastegate connection becuase the rubber ones kept melting over the manifold. I use regular rubber for the rest.
Brad
Brad
If you do use silicon make sure it isnt the thin walled ****. I had some thin walled stuff and when I was in vac the hose would collapse
maxogsr
18
Dec 27, 2008 03:41 PM
almostboostedgsr
Mar 14, 2007 08:23 PM
Acura_I-RS
Mar 29, 2003 03:25 PM
