Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
04 Pilot heating issue
Old Jan 28, 2009 | 05:53 PM
gonzoman's Avatar
Default 04 Pilot heating issue
my 04 Pilot's front heating vents only blow out cold air but the rear vents blow out hot air what should i do.
Old Jan 29, 2009 | 06:01 AM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: 04 Pilot heating issue
Check the hot water valve under the hood by the firewall and make sure it's moving with the temp control ****. If it is moving check both heater hoses to see if they are hot. If they are both hot then you have a blend door problem in the dashboard. If one is hot and the other is just warm or cold then you have a broken blend door. If it is not moving with the temp ****, the cable slipped off or once again the blend door is acting up.
Old Feb 4, 2009 | 12:52 PM
gonzoman's Avatar
Thanks for the info but do you have a DIY thread that I can use. thanks
maznkid
Oct 21, 2011 05:44 PM
tlovaj
Aug 14, 2007 11:18 PM
stivic
Nov 27, 2006 08:32 AM
idewson
Mar 8, 2006 04:12 AM
97turboteg
Feb 18, 2006 05:54 PM
