converting power to manual steering question.
Old Jan 28, 2009 | 05:26 PM
stiffinEK's Avatar
Default converting power to manual steering question.
i am converting my steering into manual.
the car is a 96 civic. (came with poewr steering.)
i got the manual steering rack and pinion from a donor car and was wondering is that all i need to convert it?
i heard i also have to change the sub-frame/cross member also?
is that true? can someone confirm it?
i know for EGs you have to change the subframe/ cross member.
any help gladly appreciated! *thumbs up*
Old Jan 28, 2009 | 05:42 PM
iliv2xlr8's Avatar
Default Re: converting power to manual steering question.
I converted the power to manual, using the power rack. Quicker ratio and Energy Suspension Poly Bushings.
I did a write-up on this. Just search.
As far as the swap goes, I'm not sure. If the mounting bolts are the same then you should not have to swap sub-frames. I would cross reference the part numbers on the tie rods to confirm they are the same. Other than that, I don't think there is much else.
-XLR8
Old Jan 28, 2009 | 06:11 PM
stiffinEK's Avatar
cool. your write up is about the 92-95 civics. i have a 96 EK and i have a manual steering rack and pinion. it have none of those power steering lines.
the thing i am wondering is if the manual steering rack and pinion would fit a power steering subframe/cross member.
or vice versa.
i was told that i have to change the subframe/ cross member in order for the manual steering rack to to work.
Old Jan 28, 2009 | 06:16 PM
iliv2xlr8's Avatar
hmmm.
Not sure.
I would cross reference the crossmember part numbers. Try here:
http://www.hondapartsdeals.com/honda_parts.php
Someone with more Ek experience might chime in.
Old Jan 28, 2009 | 06:51 PM
stiffinEK's Avatar
i cross reference my 96 civic cross member, and steering joints, and they are both the same part numbers.
when i asked the 'master mechanics' at the salvage yard i picked up my manual steering rack from, they say the part numbers dont matter, they can still be different.
Old Jan 28, 2009 | 06:57 PM
iliv2xlr8's Avatar
Not sure man.
Have you googled it?
Some other forum might have a write-up on an Ek to confirm...
Old Jan 28, 2009 | 07:39 PM
Jimster480's Avatar
or vice versa.
wait your takiing power steering out?
And what would you need to convert TO power steering? because my friend really wants to do it on his EK hatch after driving my EX Coupe.
Old Jan 28, 2009 | 09:11 PM
stiffinEK's Avatar
yupp.. i want power steering out.
i want to know if i need the non-power steering cross member/ sub-frame in order for my non-power, manual rack and pinion.
Old Jan 29, 2009 | 10:15 AM
stiffinEK's Avatar
anyone?
Old Jan 30, 2009 | 03:49 PM
mamonster's Avatar
stiffinEK,
the following link might help, been doing research for days, I had a problem with my ride, not a honda, mazda 323 protege 96...
https://honda-tech.com/forums/acura-integra-type-r-8/how-power-steering-manual-184202/
Old Jan 30, 2009 | 07:38 PM
NXSpoon's Avatar
I converted from power steering to manual in my 99 Si. I pulled out the entire power steering system and swapped in a manual rack from a CX. The only other part that you will need to get, if I recall, is the "u-joint" that connects the yolk from the steering column to the yolk on the rack. The "yolk" (the cylindrical part that has serrations) is different on the manual rack as opposed to a power one. I believe it is a smaller diameter on the manual. I had to go to the dealer and went through 3 of them before I got the right piece.
Old Jan 30, 2009 | 07:40 PM
NXSpoon's Avatar
And yes, on my car (which is probably the same as all other 96-00 Civic in this regard) the K-frame and all other bolts were fully compatible with the manual rack.
Old Jan 30, 2009 | 11:15 PM
stiffinEK's Avatar
cool! thanks! gladly appreciated! i just did mines just today, and it fits perfect, and when i match up the power and the non-power. they both have the same diameter, and mounting linings are all perfect.
steering is no problem, but for some reason now, my steering feels kinda loose the first 20 degrees going left and right. any suggestion to that?
Old Jan 31, 2009 | 07:16 PM
Jimster480's Avatar
so the same way you ripped out your PS. What would I need to convert a car from MS to PS?
Old Jan 31, 2009 | 08:06 PM
boostnbee's Avatar
sounds like you left something loose or didnt put something in right, you need to check that out before you drive anywhere. you dont want this turning into a horror story of how you were going down the road and lost steering all together
Old Jan 31, 2009 | 08:17 PM
Davus's Avatar
Have you done an alignment yet?
Anyway, I did the same thing in my 96 Civic EX when I blew up the power rack. Have you completely bolted down the steering column/rack linkage tightly? It could simply have play there in between teeth. Also, are your outer tie rods replaced and greased now?
It could just be the way a manual rack feels in general. I'd check mine but it's incapacitated. :-)
Old Feb 1, 2009 | 02:18 AM
stiffinEK's Avatar
for EKs... you ONLY need to get a manual steering rack/ rack and pinion and of course, like what NSXspoon says, you will need that u-joint and yolk to fit it in within the steering column and the pinion. and it directly bolts onto your subframe/ cross member without no problem.
but in your case, you have manual steering. all you need is to get a power steering rack and pinion, power steering regulator, and the lines and that canister thing where you put fluid, and also the power steering belt. but DONT DO IT!
but for EGs... you will HAVE to change apart its cross member/ subframe in order for it to fit correctly.
i just did an alignment today, my steering wheel does not feel much of losse steering from each turn 20 degrees off no more. it feels more of 10 degrees off though, but when i asked the mechanic that did my alignment. he said 10 degrees is fine for free play because for manual, it needs its movement when you steer at its post of where you need to be like for instance; parallel park. but other than that. my steering is super firm and its a bitshhh to turn, but i feel wayyy more power to the motor and yet i get a workout. LOL.
Old Feb 1, 2009 | 09:48 AM
Jimster480's Avatar
nah well see i have an EJ8 (EX Coupe) so I have PS, but my friend has a EG6 (DX Hatch) and he really wants PS. After driving my car he said it would be sick if he could have PS in his. So he started asking me if it was possible to do.
Old May 10, 2009 | 02:59 PM
dohcem1's Avatar
Non-power rack can't use the power rack subframe. You need to change.
Old May 10, 2009 | 04:44 PM
Jimster480's Avatar
I know this. But you can convert it by replacing the subframe. Its really not that complicated. We already looked into it before, he just doesnt have the $ for the parts.
Old May 12, 2009 | 11:02 PM
dohcem1's Avatar
anyone knows how to make the manual rack less "loose"? It feels like the steering has too much slack while the car is moving.. sorry didnt mean to jack thread.
gotenz90640
Mar 19, 2016 03:57 PM
DohcVtec77
Mar 19, 2016 03:34 PM
lordbucanero
11
Feb 19, 2013 02:42 PM
FrankencrxBHAM
Mar 2, 2007 10:50 PM
aeolus
May 11, 2003 11:03 AM
