Please Help....Oil in plugs
Old Aug 7, 2002 | 04:41 PM
LegendKing's Avatar
Default Please Help....Oil in plugs
I went to change the plugs on my girl's 92' Accord LX sedan, and she has oil in each spark plug. I know there are "plug seals" that are under the valve cover. How hard are these to change? Anyone have experience with these? I did a search, but it came back with no information. Thanks in advance!
[Modified by LegendKing, 1:42 AM 8/8/2002]
Old Aug 7, 2002 | 04:52 PM
H23 Power's Avatar
Default Re: Please Help....Oil in plugs (LegendKing)
the plug seals are easy to change...20 min max
Old Aug 7, 2002 | 05:38 PM
John's Avatar
New User
Default Re: Please Help....Oil in plugs (01GSR)
Yeap, and cheap, only a few bucks a seal too...
Old Aug 7, 2002 | 05:53 PM
accorracer's Avatar
Default Re: Please Help....Oil in plugs (DunReit)
just make sure you get a new valve cover gaskett just take off your valve cover and look around the spark plug holes in the v.c. and replace the rubber gasketts put it back together and your done
Old Aug 7, 2002 | 07:59 PM
mailforjon's Avatar
just hope its not a blown head gasket. i had that same problem, i replaced all my valve cover gaskets and o-rings, and still found oil in the plug wells. make sure you torque the valve cover bolts. i think its something like 7lb/in...i dunno, get a helms, id tell ya, but mine is out in the garage
Old Aug 8, 2002 | 08:09 AM
LegendKing's Avatar
Default Re: Please Help....Oil in plugs (mailforjon)
Thanks for all the replies gang. I'm heading out to the dealership to pick up the VC gasket and Plug seals this afternoon. I'll let you know how it goes. Thanks again!
Old Aug 8, 2002 | 07:47 PM
LegendKing's Avatar
Well, everything was done this afternoon/evening. Thanks for all the helpful posts, all went well!
Old Aug 8, 2002 | 08:16 PM
KTeller8's Avatar
always good to get a follow up
t0kyoStatus
Nov 26, 2008 07:05 PM
turboteg90
Oct 9, 2007 04:53 PM
Hey Whats Up
May 5, 2005 04:46 PM
xintegr
Mar 18, 2005 08:00 AM
PH3593A
Aug 1, 2004 04:05 PM
