stock engine swap
Old Jan 28, 2009 | 03:10 PM
ciiivic89's Avatar
Default stock engine swap
Any Advise im finally swaping my stock engine 89 si 279,000 engine for a stock 90 si engine with tranny i bought timming belt water pump and engine mounts. The engine is maintened my dealer only i have all the records!
Old Jan 28, 2009 | 03:14 PM
domokun!!!'s Avatar
Default Re: stock engine swap
what is your question...?
Old Jan 28, 2009 | 03:22 PM
4drEF's Avatar
Keyboard Humorist
What advise are you looking for?
Buy a Honda service manual (not a Haynes) and it tells you what to do step by step.
Get tools.
Do work.
As long as the engine is out, might as well do a FULL rebuild.
Hey - while you are at it, why not some Viarta's and a turbo!!
Old Jan 28, 2009 | 03:33 PM
ciiivic89's Avatar
the motor has 135.000 miles i just want some advice the motor is out and ready for install so is the tranny i really dont know much just want install it and keep it stock besides intalling new motor mounts and changing timming belt and water pump and seals any other suggestions? oh the tranny is rebuilt new stock clucth and flywheel has about 30.000 miles
Old Jan 28, 2009 | 03:44 PM
Purplelv's Avatar
i still dont see what your needing advice...replace the timming belt and water pump then stick it in and drive are you asking advice on how to put it in or what to do to the new motor besides timming belt and water pump?
Old Jan 28, 2009 | 03:46 PM
Radim's Avatar
Not really any advice we can give you, pretty much it's a straight swap everything will bolt in fine. Flush your radiator replace the oil and coolant once it's running do a tune-up.
Don't forget your headlight fluid either.
Old Jan 28, 2009 | 03:49 PM
ciiivic89's Avatar
should i change any other parts besides the ones i mentioned?
Old Jan 28, 2009 | 03:56 PM
ciiivic89's Avatar
haha i bought slick 50 headlight fluid already
Old Jan 28, 2009 | 03:59 PM
jhammond_82's Avatar
Reject Papi
before you put the new motor in, why not give it a good paint job? duplicolor engine paint, keep that bay looking nice. just my .02 though.
Old Jan 28, 2009 | 04:22 PM
TenTwelve's Avatar
Royal Purple>Slick 50 for headlight fluid and blinker lube.
Nocturnal
Feb 23, 2009 10:41 AM
lend_type_R
May 12, 2008 07:15 PM
davidluko
Oct 4, 2006 09:17 PM
GruvyTune
May 22, 2002 07:20 AM
