ls sleeved block gsr crank what bearings
Old Jan 28, 2009 | 03:05 PM
POORMANT's Avatar
Default ls sleeved block gsr crank what bearings
like title says i have a sleeved ls block gsr crank what bearings should i use lmk thanks
Old Jan 28, 2009 | 06:52 PM
turbociv910's Avatar
Default Re: ls sleeved block gsr crank what bearings
all b series are the same, get te code off the crank..
Old Jan 29, 2009 | 05:15 AM
Semnos's Avatar
Main bearings are the same, but you need gsr rod bearings they are narrower.
If you're going to get ACL bearings get the GSR bearings set.
jsalter@butte
Engine Machining & Assembly
Aug 20, 2016 03:50 PM
sh!ft
Apr 14, 2010 04:20 AM
nytosc
10
Apr 7, 2009 05:48 PM
boostd ls
Mar 6, 2008 02:02 PM
drift2004
Nov 21, 2005 03:54 PM
