j30a1 vs j32a2
will a j32a2 be a direct bolt in on a 2001 accord that already has a v6? if not where can i find info on doing the cams and intake swap from a j32a2 into my j30a1 i found a CLS motor for $500 and id rather do that instead of tearing the heads apart
Cheapest price I found on the cams alone was $260 shipped from Majestic Honda (google search) brand new. I'd buy the motor whole if I were you. That way, you could use the heads, TB, and cams, which will cost you WAY more than $500 if bought new (and probably used in a lot of situations). Albeit I'm a newb here and don't know much about the specifics of this swap, but those things will directly bolt on and they aren't cheap new.
I think the J30a1 tranny will bolt directly up to the J32a2, so if you just wanted to use the whole motor, you would need the CL-S ECU and not sure about the motor mount locations.
Anyone more experienced care to verify/shoot down the info in this post?
It's a relatively straight forward process as far as hardware goes... It should bolt right up, but the ECU is something you will need to pick up. I'd also recommend ditching the automatic transmission because it can't even handle the stock power.
i found a cls not too far from me and they want 500 for the motor so i think ill try to aleast get the trans from it it should be stronger than the accord trans. if anyone knows anything about doin this swap please let me know what wont work so im not wasting my time and money on this. mount and wiring problems, if any would be appreciated.
Register with www.v6performance.net and do a search for all your swapping needs with that motor and transmission combo.
The '98-02 Accord V6 trans was a 4-speed automatic, similar to the one found in '97-99 3.0CLs, '99 3.2TLs, and '99-01 Odysseys.
Power Rev Racing
Apr 24, 2006 08:10 PM
