Welding Titanium
Old Jan 28, 2009 | 09:43 AM
hybrid2007's Avatar
Default Welding Titanium
Has anyone got any tips for welding grade 2 Ti?
I'll be welding 1" 20 guage tube and some 3mm sheet. I have a gas lens and I'm setup to purge the inside of the tube.
I'm thinking of making up something that will allow me to purge the backside of a HV fillet when welding the sheet?
Should I be trying to set something up that will allow me to purge the entire area near the weld?
This is not a job for a customer, purely practice. If this comes out ok then we will start to use Ti alot more.
Old Jan 28, 2009 | 10:05 AM
Nick Z32's Avatar
Default Re: Welding Titanium
expensive practice....
ss is very similar to Ti (welding wise) , why not practice on that
Old Jan 28, 2009 | 10:21 AM
hybrid2007's Avatar
Sorry I should have said before, im a fairly competant tig welder. I do alot of SS and aluminium.
My manager wants me to see if its feasable for us to fabricate with Ti in house rather than contracting it out.
I managed to get a metre of 1" 20guage tube, and 200mm square of 3mm plate plus a few rods for free so its not costing anything.
It's not really the welding I'm after advice on, more the purging and prep.
Old Jan 28, 2009 | 10:47 AM
racebum's Avatar
http://www.thefabricator.com/ArcWeld...cle.cfm?ID=878
Old Jan 28, 2009 | 11:21 AM
hybrid2007's Avatar
Thanks that was a good read!
Is there a way of telling when the weld has dropped below 500 degrees?
Old Jan 28, 2009 | 01:18 PM
Nick Z32's Avatar
thats a good link..
just make sure your metal is super clean
Old Jan 28, 2009 | 01:54 PM
91jdmhatchback's Avatar
i think welding ti is alot about your purging setup, i watched a vid, and they did a weld with and without a purge on the backside. the non purged weld, cracked as it cooled.
Old Jan 28, 2009 | 06:01 PM
random_tuner's Avatar
There was just a big thread about this.
https://honda-tech.com/forums/welding-fabrication-53/those-experience-titanium-2473966/
Good info.
Old Jan 29, 2009 | 11:33 AM
hybrid2007's Avatar
I had seen that one, one of the posts is very informative.
That thread was mainly to do with wall thickness so was hoping somebody would have a bit more to add.
The Ti should be here early next week so once i've had a go i'll get some pictures up.
Old Feb 2, 2009 | 02:46 PM
i drive a honda's Avatar
go on craigslist and pick up a stock superbike exhuast for cheap?
Old Feb 2, 2009 | 04:05 PM
Nick Z32's Avatar
lol yeah GREAT idia
Old Feb 2, 2009 | 10:19 PM
hybrid2007's Avatar
The titanium is already on its way to me.....
Old Feb 2, 2009 | 11:53 PM
HiProfile's Avatar
If its structual, make sure its clean-room spotless and you use enough gas. Titanium really doesn't like hot temps, in terms of keeping its strength.
It also doesn't conduct heat well, about half that of most SS.
Old Feb 4, 2009 | 07:39 AM
damnraz's Avatar
When yo get the Ti, PM me I'll help you out.
Old Feb 5, 2009 | 09:27 AM
hybrid2007's Avatar
Thanks man I appreciate it.
Old Feb 5, 2009 | 01:47 PM
onefstek's Avatar
Get a really big cup with a gas lense and make sure you backpurge.
Old Feb 6, 2009 | 04:02 PM
92exaccord's Avatar
Welds just like ss as posted above, I welded some that was under a 32of and inch and was pretty easy. just seemed like the puddle was sticky when dipping
Old Feb 14, 2009 | 07:39 AM
Toysrme's Avatar
its easy once you do it. doesn't flow nearly as well as steel when you work it. common mistake is to overheat it. as should be obvious, you should have a good purge/post perge setup. its easy enough. a GOOD (not backyard yabo) stainless / aluminum welder should be able to make ti welds after a minimum of practice.
dcen preffered, ac with a large dcen balance will work if you must.
Flashmn
Welding / Fabrication
Oct 31, 2005 03:44 PM
yellowturbo
11
Mar 12, 2005 10:00 PM
ivsihi
Feb 14, 2005 07:52 AM
Bailhatch
Jan 25, 2004 07:41 AM
