Welding manifolds with a 110v 135amp MIG?
Old 01-24-2004, 05:33 PM
Bailhatch's Avatar
Default Welding manifolds with a 110v 135amp MIG?
stupid idea? I can lay some nice beads with my oxy/act setup but i am getting a MIG setup shortly and it will be a house current 135amp gas shielded rig probably a lincon. Would I have better luck doing a tubular style rather than log because of the material thickness? what about 3/8" flanges? Thanks
Old 01-24-2004, 08:14 PM
rtype11's Avatar
Default Re: Welding manifolds with a 110v 135amp MIG? (Bailhatch)
if its the mig pak think the limit is around 3/8 mild steel, try the New welding thread, they will know for sure.
Old 01-25-2004, 04:17 AM
Phoenix GSR's Avatar
I have the lincoln 135amp 110v mig welder and it does log manifolds fine, and I use 1/2" flanges... the first one I made I cut open and tried to smash it witha hammer, tried to break the welds in a big vice and it didnt give.. it will be plenty strong..
I laid my beads slow with a lot of wirespeed, so they were pretty big, then I went back and smoothed them out with a grinder.. it was a giant PITA, but it worked out nicely...
hth
Old 01-25-2004, 06:51 AM
Bailhatch's Avatar
Default Re: Welding manifolds with a 110v 135amp MIG? (Phoenix GSR)
excellent!
I'm glad to hear you tested it too. I was planning on buying some stock to just weld up and smash myself. So the welds were pretty ugly? do you think it was you or the machine?
Old 01-25-2004, 07:41 AM
Ri5e's Avatar
Got any pics?
HellaFab
Welding / Fabrication
05-27-2013 04:38 PM
TurboEM1
03-11-2006 08:46 PM
.water
05-20-2005 11:47 PM
toolowsol
12-15-2004 10:45 PM
Tbone
08-12-2004 01:54 PM
Quick Reply: Welding manifolds with a 110v 135amp MIG?
