B20b + 95 teg LS wiring harness + P75 = halp!
Old Jan 28, 2009 | 07:20 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Default B20b + 95 teg LS wiring harness + P75 = halp!
Ok, my car currently is an OBD-0 B16 in what was originally a DPFI 91 sedan.
I has a B20B fresh from Hmotors with all the OBD-2 sensors/dizzy still on it.
I has a P75 manual ECU.
I has a 95 Teg complete uncut wiring harness w/ a OBD-1 LS distributor.
And I also has the clusterfvck of a wiring harness thats on my B16 now (it all works, just was done really sloppy, lots of same colored wire and extra slack everywhere).
Mechanically I have no worries about the swap, but all my previous swaps were remaining OBD-0. I never really grasped the going from OBD-0 to OBD-1.
So what do I use? Try to repair / refinish my current OBD-0 harness? Which plugs do I need to change to use an OBD-1 Ecu? I'm like 99% sure I need a jumper harness from boomslang, jk tuning or the like, other than that I have no idea what to expect wiring wise. Halp!
Old Jan 28, 2009 | 07:59 AM
89vwfox's Avatar
Default Re: B20b + 95 teg LS wiring harness + P75 = halp!
4 wire o2 sensor obd1 injectors and pig tail clips (passwordjdm sells them i think) obd1 dizzy obd1 non vtec ecu obd1 alternator pigtail obd0-obd1 jumper (jhp has them for about $100) Rywire obd0-obd1 dizzy jumper u will no longer need your resistor box u can solder on all the pig tails yourself on to your existing civic harness im pretty sure that's it im currently running obd1 b20 in my 90 civic si
Old Jan 28, 2009 | 09:19 AM
mpls's Avatar
to make your car obd1 you have to get dizzy,dizzy jumper,ecu,ecu jumper
Old Jan 28, 2009 | 09:54 AM
ComeOnKip's Avatar
So use my exsisting harness and just get a few pigtails?
Old Jan 28, 2009 | 10:04 AM
TenTwelve's Avatar
Do you haz a cheezburger?
Old Jan 28, 2009 | 10:06 AM
ComeOnKip's Avatar
I had a cheezburger, they took it along with mah bukkit.
Old Jan 28, 2009 | 10:46 AM
mpls's Avatar
rite on
Old Jan 28, 2009 | 01:04 PM
ComeOnKip's Avatar
sweet. thanks guys.
DA john
15
Mar 23, 2013 12:45 PM
E_F_9
Dec 22, 2005 02:26 PM
Cain Marko
Jul 7, 2004 02:40 PM
Mefain
Feb 16, 2004 09:39 PM
