help fuel pump will not turn on
Old Jan 27, 2009 | 07:28 PM
lsvtechatch92's Avatar
Default help fuel pump will not turn on
ok guys the fuel pump will not turn on when i put the key forward position.... main relay is good.. all fuses are fine... and pump powers on when i hook it up directly to battery.... also the cd player will not come on either... i totally stripped the car a year ago to start a build and putting it back together got the interior in it and no power to radio or pump and both i know work... i have good grounds and all other electrical stuff work... windows, lights, dash, etc.etc.etc.
Old Jan 27, 2009 | 07:31 PM
Former User's Avatar
Default Re: help fuel pump will not turn on
Is fuse 31 or 18 blown? Also check the important ground wire on the thermostat housing. It may be loose or corroded.
Old Jan 27, 2009 | 07:42 PM
i figured it out... it was no ground from valve cover i thought i had already did it overlooked all of it and i forgot to put it on
SPUNKYMUNKY
11
Mar 27, 2015 03:58 PM
lakahang
Aug 11, 2011 07:37 PM
crxb16sir
Dec 14, 2009 09:56 PM
veritasaequatis
Classic Hondas
Feb 20, 2009 05:32 PM
incognito E46
Feb 21, 2006 05:33 PM
