Oxygen Sensor Wiring
Old Jan 27, 2009 | 05:51 PM
hondateg10's Avatar
From: Somewhere in the United States, united states
Default Oxygen Sensor Wiring
I got a 90 civic hatch dx with a d15b2. My oxygen sensor wire has been cut and i need to know where it goes. what wire color does it needs to be connected to? i have 3 wires that come out of the eng harness that is not connected to anything.... yellow, green/blk, and white with a grey covering.
Old Jan 27, 2009 | 05:56 PM
sgallagher's Avatar
Default Re: Oxygen Sensor Wiring
The O2 sensor is only 1 wire. I'm pretty sure the yellow and the grn/blk wires are from your reverse switch.
Old Jan 27, 2009 | 06:17 PM
hondateg10's Avatar
yes i know this. i just need to know what wire connects to the wire off the o2 sensor
Old Jan 27, 2009 | 06:52 PM
sgallagher's Avatar
Well..... if the yellow and the grn/blk wires don't connect to the O2 you don't have much of an option now do you.
Old Jan 27, 2009 | 07:16 PM
bobbyisking's Avatar
lol...
Old Jan 28, 2009 | 08:38 AM
hondateg10's Avatar
what the hell are you talking about? neither does the white with a grey coating on it!
from a wiring diagram it show that the black wire coming out of the o2 sensor turns into a white wire at the ecu. so is the white wire with the grey coating over it the wire that the o2 sensor wire connects to?
Old Jan 28, 2009 | 09:00 AM
hondateg10's Avatar
please, someone give me some helpful info. instead of trying tell me what i do and don't have like sgallagher
Old Jan 28, 2009 | 09:50 AM
4drEF's Avatar
Keyboard Humorist
Which wiring diagram are you looking at?
Old Jan 28, 2009 | 10:05 AM
xci_ed6's Avatar
it is the white wire, it is black to the connector, after the connector it is a shielded white wire. The grey is the covering for the shield.
Old Jan 28, 2009 | 10:09 AM
hondateg10's Avatar
so this is my wire i need to butt connect to?
Old Jan 28, 2009 | 12:53 PM
xci_ed6's Avatar
yes, but don't use a butt connector. Use crimp on bullet connectors, do not solder the sensor side, you can solder the harness side if you want to. Heat shrink both sides, and it would be a good idea to put heat shrink over the entire connection. The O2 sensor is low voltage, so any extra resistance can cause misreadings at the ECM.
Old Jan 28, 2009 | 04:35 PM
sgallagher's Avatar
You said you have 3 wires which are not connected to any thing. The yellow and the grn/blk wires are supposed to connect to the reverse switch. And the white with the covering is supposed to connect to the O2 sensor. I've already told you twice.
Your DONE..
toxictom
Jun 15, 2017 10:42 AM
redflaredb1690
May 12, 2006 01:56 AM
hondaracer.com
Oct 30, 2004 07:08 AM
Flexmyrex
Apr 7, 2003 06:52 PM
