y8 wont start
Old Jan 27, 2009 | 12:11 PM
efsedanfan's Avatar
Icon3 y8 wont start
ok so this is my first single cam build and I just got the obd2 y8 installed with obd1 dizzy, jumper, p28, and obd0 injectors runnning on resistor box. my problem is that I'm getting a crank pos sensor error code (4). I know that normally in the past this has been automatic dizzy for obd0 but I noticed the y8 has a sensor coming off of the crank and i dont know if the ecu needs to read that or if its getting it from the obd1 dizzy... also it's not starting. please help! thanx
Old Jan 27, 2009 | 12:13 PM
efsedanfan's Avatar
Default Re: y8 wont start
going back downstairs to test spark..
Old Jan 27, 2009 | 12:26 PM
jlicrx's Avatar
the sensor by the crank pulley is the crankshaft fluctuation sensor - the OBD1 ECU doesn't read that sensor - not needed with OBD1 - try switching the orange and white wires at the distributor connector
Old Jan 27, 2009 | 04:31 PM
efsedanfan's Avatar
checked spark.. got nothin on all four.
swapped orange and white.. nothin.
checked cap/rotor.. seem fine.
getting replacement/test dizzy tonight to verify bad dizzy..
any other ideas please help!
Old Jan 28, 2009 | 08:29 AM
EJ8CIVIC's Avatar
possibly try fuel relay or try looking over the ground wires
i have a y8 in my crx and i didnt tightn my grounds and it wouldnt start
Old Jan 28, 2009 | 12:45 PM
efsedanfan's Avatar
yup dizzy is bad but i got the wrong one. does anyone know.. should i get one for a y7? does it fit?
Old Jan 28, 2009 | 04:49 PM
EJ8CIVIC's Avatar
im runing a 92-95 dx dizzy on my y8 head
backwoodslife94
Nov 13, 2016 12:20 PM
Twisted Image
Feb 14, 2009 12:23 AM
SovXietday
Sep 16, 2008 08:34 PM
Frost7177
Jun 27, 2007 06:26 PM
inh
Jul 30, 2006 06:38 PM
