oil leak!?!?!?
Old Jan 27, 2009 | 12:07 PM
the king.'s Avatar
Default oil leak!?!?!?
i just noticed i had a small oil leak with my car, and on there ground there is a little bit left but when i opened my hood i had some oil on the valve cover a bunch on the alternator and some on the bottom of the hood! can someone please tell me what is wrong so i can fix this oil leak.
i even have pictures
Old Jan 27, 2009 | 12:08 PM
eMpAtHy's Avatar
Default Re: oil leak!?!?!?
maybe your gasket for you valve cover went bad. see if the leak has started there.
Old Jan 27, 2009 | 12:10 PM
the king.'s Avatar
sry for the crappy cell phone pics
Old Jan 27, 2009 | 12:23 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
pics don't help my decision sorry
Old Jan 27, 2009 | 12:54 PM
WhiteOnRice's Avatar
How you taken the valve cover off recently?
Old Jan 27, 2009 | 02:45 PM
the king.'s Avatar
i have never taken the valve cover off
Old Jan 27, 2009 | 09:32 PM
eMpAtHy's Avatar
on my sisters old integra, the valve cover gasket dried out and started leaking oil and she never took her valve cover off. i replaced it and it was fine after that.
Old Jan 27, 2009 | 09:33 PM
eMpAtHy's Avatar
oil is not immune to gravity, so find the highest point and that should be where it starts from. are you sure you didn't spill any oil when you were refilling it with oil?
Old Jan 28, 2009 | 09:32 AM
If it's on the hood I'd inspect the 6 rubber bushings under the washers that hold the cover down.
Old Feb 3, 2009 | 11:12 AM
rsxpat's Avatar
ummm dumb question..........is the oil cap in place?????? lol hahaha if so, check the valve cover gasket, and the valve cover stud holes where the cover nuts tighten the valve cover down. these are both prone to dry rot issues.
did you use any corrosive cleaners or high pressure water / engine degreaser recently???
if so, then the gasket is most likely destroyed.
Old Feb 3, 2009 | 12:03 PM
SlimDC5's Avatar
Look at your passenger motor mount, good chance that it blew and got hydraulic fluid everywhere
Old Feb 3, 2009 | 12:07 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
^ thats what I was thinking at first.... ugly brown nasty fluid?
Old Feb 3, 2009 | 08:29 PM
hawaiiancb74's Avatar
check the seal on the tensioner door on the chain cover.. it is sealed with honda bond but can eventually leak i guess. make sure your oil filter is on tight.(not too tight tho)
stupidasso15
24
Oct 5, 2011 12:49 PM
jakop92
Nov 15, 2009 11:33 AM
Civic_07
29
Jul 6, 2009 06:05 PM
J.nguyen
Dec 13, 2005 12:12 AM
ITR_1211
29
Dec 24, 2003 08:15 AM
