interior dash
Old Jan 27, 2009 | 10:52 AM
kmeng's Avatar
Default interior dash
how do you change this.?
Old Jan 27, 2009 | 10:58 AM
kmeng's Avatar
Default Re: interior dash
i have a new one to replace because the one thats on right now is broken cause some ****in theives broke it when my uncle owned the car..and mine is a LHD
Old Jan 27, 2009 | 11:07 AM
94EG8's Avatar
Seagull Management
Its held on by several screws, you need to remove the dash to get at them.
Old Jan 27, 2009 | 11:15 AM
sp00ledbseries's Avatar
yep take out the whole dash
Old Jan 27, 2009 | 12:43 PM
kmeng's Avatar
damn..that sucks!!! but thanks for the help
Old Jan 27, 2009 | 04:59 PM
danomatic93's Avatar
This is for 92-95 civics. Here's a link to the post: http://www.hondacivicforum.com/m_370588/tm.htm
Here's how:
For starters, you have to be committed to take off the whole bezel (the thing that frames the heater control, cd player, and steering wheel.
If you aren't, then DON'T. It is a total bi**h to do.
Here's how:
1.Start by doing the easiest thing. Remove the cd player and the part below that (that has the coin tray and cig tray/lighter on it).
2.Remove the kick panel (the thing your knee hits when you are sitting)
3.Remove the metal 'safety' bar that is behind the kick panel.
4. Remove the Gauge bezel (to do this pop out hazard button [it pops out], remove all screws. The bezel frame should come out. It's attached by clips and the screws you removed) Then unscrew the guage bezel and remove it.
5. Now for the second hardest part. Remove the heater control unit. (It's easy if you do it a lot, which I do, but whatever) You basically have to do yoga to get to the screws that hold the unit in. There are three, i think. Two are near the front underneath. The other is near the back underneath. Once unscrewed, remove the metal wire (that controls the temp setting). Please don't bend it too much. Now you can pull out the unit.
Recap:
You removed the cd player, the heater control unit above that, the coin tray/cig tray/lighter piece below those, hazard switch, and guage bezel.
Now that your dash it completely in pieces you can get to the damn screws that hold the main bezel to the dash.
6. There are 7 or 9 screws that hold the bezel on. I suggest to use a small mirror to find them before you go nuts. You had to remove all of those parts to get a screwdrive at the proper angle to remove them. Get a collection on phillips screwdrivers handy. Get a short one, long one, angled one, any kinds you can the get the right angle. Once you get all the screws you're done.
Please allow a day or two to get this done. If you have never removed these things, it will take a long time.
Feel free to ask any questions whenever. I would suggest for you to get a Chiltan's manual or a cheap haynes manual to fit some pics of the insides.
GOOD LUCK!
Disclaimer:
You acknowledge that I shall not be responsible or liable, directly or indirectly, for any damage or loss caused or alleged to be caused by or in connection with use of, or reliance upon, any such information, material, products, or services.
Old Jan 27, 2009 | 05:38 PM
kmeng's Avatar
thanks alot danomatic93..
Old Jan 27, 2009 | 06:47 PM
twiztid_989's Avatar
Yep i agree cuz i broke mine in my car and i had to take it all apart to put another one in
danomatic93
12
Feb 7, 2013 07:50 AM
sixfiveoh
Aug 8, 2009 10:43 PM
Tommy_Gunns
Mar 2, 2006 02:53 PM
SlowSOHC-T
Nov 18, 2004 04:22 AM
SlowLSTeg
Jun 11, 2002 07:02 AM
