1990 accord won't get spark or gas!!!?really fustrated!!!!!
Old Jan 27, 2009 | 09:00 AM
chad olson's Avatar
Default 1990 accord won't get spark or gas!!!?really fustrated!!!!!
i been tryin to get my accord running for the longest time the car does not have spark or gas it started about 2weeks ago but when it did it only rev to 3,500rpm and thats it now it does not start at all ????? should i change the dizzy or what????some one please give me a idea i had the car for 8years it means alot to me...oh!!and i changed the ecu main relay and still nothing?
Old Jan 27, 2009 | 09:03 AM
GhostAccord's Avatar
Default Re: 11990 accord won't get spark or gas!!!?really fustrated!!!!!
Can you hear the fuel pump prime the fuel system when you turn the key to the on pos? (KOEO)
What made you replace the Main relay and ECU? Did you test teh electrical circuits or just replace because someone suggested to replace them? It could be something as simple as a short in a wire but if you haven't done any testing you will never know just by replacing parts.
Old Jan 27, 2009 | 11:49 AM
chad olson's Avatar
i replaced the main relay cause the one i had on there was clicking alot so i thought it was the relay but it was not????then i was trying to receive the ecu codes from the ecu but the cel was not flashing at all so i thought that was it but still nothing????no i didn't do any test yet???i don't really no how to do test????what should i do next???
Old Jan 27, 2009 | 12:27 PM
The no flashing ECU with the pins shorted means that there are no codes stored on the ECU, Not that there is something wrong with it. A solid cel with the pins not shorted means the ECU is F#@k'd. I think I remember posting that in one of your threads already...but maybe it wasn't your thread, I've posted that info in so many CEL threads now.
Your best bet if you are not familiar with electrical trouble shooting would be to find a Honda Shop Manual. There are great trouble shooting guides and how too's in them to get you started with testing electrical problems.
Old Jan 27, 2009 | 12:35 PM
chad olson's Avatar
ok ill check it out???one more thing does the ignition moduel controll fuel too???
Joshua Panola
Feb 19, 2018 05:13 PM
d-alva54
Oct 25, 2014 10:56 AM
95wagon
Mar 21, 2014 08:58 AM
em1_racer
Jul 19, 2011 10:52 AM
sT(.)(.)k
Sep 13, 2010 12:42 AM
