Is a hot side of turbine weldable?
Old Jan 27, 2009 | 05:39 AM
pentaq's Avatar
Default Is a hot side of turbine weldable?
I've been fighting with exhaust leaks for almost a year. I'm really fed up with this. I plan to weld the exhaust side to the SS flange (this junction doesn't work now- seals, exhaust cement, decked flange- not working here) and then weld a V-band to make a connection with the rest of the downpipe.
Is it possible to weld the hot side to stainless steel? The turbo is IHI/BorgWarner RHB6 (I believe)
Thanks
Old Jan 27, 2009 | 06:17 AM
shortyz21's Avatar
Default Re: Is a hot side of turbine weldable?
chances are even if u preheat the **** outta it, and peen it while u weld it.
its going to crack because the expansion differentials are so great between those 2 products..
why cant u just pull the manifold off, and have the flange machined flat again.
Old Jan 27, 2009 | 08:46 AM
tony413's Avatar
does this answer your question
Old Jan 27, 2009 | 09:07 AM
Nick Z32's Avatar
yes you can... vband turbos have welded exhaust housings
Old Jan 27, 2009 | 11:05 AM
tony413's Avatar
not Tial if thats who you're referring to, those are made out of a single casting i believe but they CAN BE welded to
Old Jan 27, 2009 | 01:37 PM
TurboFocus's Avatar
Yes they can be welded if you are welding a cast iron turbo housing you have to use ni55 or ni99 filler rod. if its cast steel then just use ss308 filler rod
Old Jan 28, 2009 | 06:27 AM
shortyz21's Avatar
do you guys realize hes welding a cast turbo housing steel id imagine to his stainless steel turbo manifold..
those compressors u posted are cast stainless.
Old Jan 28, 2009 | 08:58 AM
tony413's Avatar
a compressor IS NOT A TURBINE.
look at my pic the TURBINE OR HOT SIDE has a WG flange welded to it.
Old Jan 28, 2009 | 11:48 AM
TurboFocus's Avatar
Its still possible either way its welding and the right filler rod
Old Jan 28, 2009 | 11:56 AM
c jackson's Avatar
threes
super missle!
Old Jan 28, 2009 | 01:16 PM
Nick Z32's Avatar
yeah ikno but this is what i was talking about... you can see that the V-band flange was welded really nicely
Old Jan 28, 2009 | 03:06 PM
pentaq's Avatar
^^^This is what I'd like to accomplish at the end more less. But the V-band won't be welded directly to the turbine but to the flange and then the flange to the turbine.
Old Jan 28, 2009 | 05:40 PM
DESTROYER's Avatar
Just weld the Vband on, why so much extra work?
Old Jan 28, 2009 | 06:09 PM
tony413's Avatar
you could just buy an aftermarket one to suit your needs
Old Jan 29, 2009 | 01:07 AM
pentaq's Avatar
The turbine had internal WG before so the shape is not round. Thats why flange-> V-band solution.
Old Jan 29, 2009 | 07:54 AM
tractionwhat's Avatar
Originally Posted by turbofocus
yes they can be welded if you are welding a cast iron turbo housing you have to use ni55 or ni99 filler rod. If its cast steel then just use ss308 filler rod
+1
Old Jan 29, 2009 | 08:52 AM
Fabian's Avatar
http://cgi.ebay.com/ebaymotors/t3-t3...Q5fAccessories like this?
Old Jan 29, 2009 | 02:01 PM
pentaq's Avatar
yep. And I'd like it to be welded to the turbine housing.
Old Jan 29, 2009 | 02:25 PM
Nick Z32's Avatar
why not just have it bolt one like that?
Old Jan 30, 2009 | 01:33 AM
pentaq's Avatar
because you didn't read the firts post.
Old Jan 30, 2009 | 08:26 AM
Nick Z32's Avatar
if your tired of exhaust leaks try using a gasket.
thouse help all the time
Old Feb 2, 2009 | 12:48 AM
pentaq's Avatar
I did use couple of them. I'm done.
Old Feb 2, 2009 | 08:29 AM
i drive a honda's Avatar
bolt 2 flanges together tightly as possible, leave bolted then run a butt all the way around where the 2 flanges meet?
morepoop4u
Welding / Fabrication
Jun 4, 2016 07:02 PM
Scott53092
Feb 12, 2014 12:54 PM
dxasylum
Mar 12, 2008 11:31 AM
93c1sol
Aug 28, 2007 06:17 AM
StolenTeg
Aug 16, 2005 05:23 PM
