4th gen h22a clutch problem
Old Jan 27, 2009 | 03:48 AM
Attley's Avatar
Default 4th gen h22a clutch problem
hi all, need some help if anyone knows, overtook a lorry last week and as i changed into 4th the clutch wouldn't fully dis-engage, it grips up to around 300rpm but any more revs and it just spins freely.
ive tried topping up the clutch fluid and bleeding it but the clutch arm is moving fully which leads me to beleive it could be a clutch problem or bearing problem, does anyone have any experience with this fault?
the car is a jdm bb1 prelude 1991 (4th gen) with a h22a engine and m2b4 with lsd gearbox,
thanks in advance
Old Jan 27, 2009 | 04:08 AM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: 4th gen h22a clutch problem
at first guess, i would say that it is a pressure plate problem... in any case you have to get that tranny out, the problem will be obvious whatever it is when the clutch assembly is laying on the ground.
Old Jan 27, 2009 | 07:34 AM
sixandhishat's Avatar
I've got the same issue - after a quick inspection I've now got a new clutch on the way
alexsneesby
Aug 18, 2010 12:11 PM
thelonerangers
Mar 14, 2007 12:13 PM
bpot555
May 23, 2006 08:34 AM
iop
May 13, 2004 06:29 AM
pentaq
Nov 6, 2002 11:32 AM
