b20 alternator in b16 Possiable?
Old Jan 27, 2009 | 03:45 AM
salman's Avatar
Default b20 alternator in b16 Possiable?
HI ALL.
I want to ask if i can swap a b20 alternator into a b16,
the reason is extra 30 AMPS that b20Z alternator offer,
I am running a 1000rms sound system, having problem of battery discharging, very fast, even with the car is at Idel, the sound system amp starts to trip. after 5 mins of heavy music....
current alternator is charging at 13.5 to 14 volts at idel., the motor is B16A OBD0. DA8 chassy..
also I have read that b16 alternator is 60 AMPS where as B20z is 90AMPS...
Please update me if the specs are wrong...
Old Jan 27, 2009 | 11:49 AM
salman's Avatar
Icon3 Re: b20 alternator in b16 Possiable?
I know its a tough Question... :/
Old Jan 27, 2009 | 04:21 PM
hondadude_rudo's Avatar
Default Re: b20 alternator in b16 Possiable?
it will bolt on and work, but im not sure about the difference in amps and such. i got out of audio a long time ago. im also not sure if the non vtec alt will like b16 rpm all of the time. ive ran ls alts on gsrs, before and had no problems.
Old Jan 27, 2009 | 04:28 PM
hatcht9x's Avatar
94 gsr gives you the extra 30 amps as well.. many people have done this
Old Jan 27, 2009 | 04:47 PM
Crx Jimmy's Avatar
Use a 94-95 gsr alt its is 92 amps I believe, and it will plug right in. the newer obdII alt have different plugs. you can also buy a rewound alt for higher amps they sell 130 amp ones.
Old Jan 27, 2009 | 09:51 PM
salman's Avatar
Yes! the GSR alternator is 90Amps and will bolt on directly, but its not available!
Actually, b20 is the only alternate available, else i definitely had installed that hi amp alternator.
Old Jan 28, 2009 | 05:43 AM
schock3's Avatar
salman if u wanna sell ur TPS pm me ill take it!
Old Jan 28, 2009 | 02:57 PM
Crx Jimmy's Avatar
you can get the b20z alt and swap the whole rear section with the voltage regulator off your old alternator and it will plug right in. its just more involved. if there is a alternator re-builder near you(check the phone book) he can just rewind yours or swap the end to the b20z alt for a couple bucks
Fresh Ej2
Mar 6, 2009 01:35 PM
alscrx
Aug 17, 2008 03:54 PM
h2point2
Mar 4, 2008 03:51 PM
playAho
13
May 31, 2003 11:57 AM
