d16y7, ek parts, teg parts
Make me an offer on any of these parts. All offers considered. Will ship anything at buyers expense. Motor can be delivered small distances. Can also install locally. Located in Springfield, MO. Please PM any offers. Thanks. Will update with pictures.
WTB/trade:
99-00 civic si lip in NBP
quiet exhaust for EK hatch ::purchased::
A/C line for 96-00 civic. need the low pressure side that connects to compressor
For Sale:
96-00 civic Comptech 22mm adjustable swaybar/tiebar combo. Currently still on car. Painted flat black but can easily be stripped to look like OEM. 300.00
new honda oem b16 coolant neck. Purchased thinking I would need it but ended up not. 15.00
new honda oem b16 radiator hose 10.00
96-00 civic dx throttle cable 10.00
96-00 d series a/c bracket 5.00
96-00 civic dx brake booster 5.00
96-98 civic hvac controls 5.00
94-01 integra timing post mount with studs 20.00
94-01 integra ac bracket 20.00
96-01 integra LS wiring harness (dizzy, CFK, IAC, evap plugs removed) Will sell individual
plugs if needed 20.00 or 5.00 for individual plugs
94-01 Integra rear wheel bearing/hub w/abs ring. May also fit civic with rear disc. 10.00
94-01 integra slave cylinder line. 5.00
misc brackets, clips, plugs. 1.00
94-01 integra front brake calipers come with almost new oem type pads. ::sold::
96-00 civic master cylinder. This is out of my 99 dx hatch so that would make it 13/16. Took it off when I swaped to discs. No leaks still worked when I removed it. ::sold::
94-01 integra motor mounts (front lowers only) ::sold::
96-00 civic dx gauge cluster ::sold to 94eg'n::
99 civic d16y7 engine swap. Has 125xxx miles. I have owned car since 2001. This engine was very well taken care of. Changed oil every 3000 with Mobile1. Tranny oil changed with honda MTF. Swap includes motor, tranny, axles, shift linkages, shifter, power steering pump, all motor mounts except upper tranny mount., header with integrated cat, alternator, dizzy, all sensors unbroken, radiator hoses, ect, ect Not really sure what its worth. ::sold::
WTB/trade:
For Sale:
cruizinmax
Apr 5, 2009 10:17 AM
9698, aftermarket, civic, d16y7, exhaust, fit, harness, hoses, mo, parts, performance, radiator, springfield, teg, wire
