Suspension & Brakes Theory, alignment, spring rates....
Chassis and suspension Comparism eg vs ek
Old Jan 26, 2009 | 06:13 PM
b20beast83's Avatar
Default Chassis and suspension Comparism eg vs ek
I was wondering...
Lets compare the Eg and EK chassis.
Say the eg9 VS ek4
Eg9 is the jdm eg with b16a engine upgraded brakes and suspension factory
ek4 is the jdm ek " " " " " "
What is the stronger chassis
And Whats is the difference in suspension and which is better?
Some say the eg, but i doubt honda will make a newer car inferior.
Old Jan 26, 2009 | 06:18 PM
batallic's Avatar
Default Re: Chassis and suspension Comparism eg vs ek
both are double wishbone, 6th gen rear lcas are slimmer, 5th gens are lighter,
Old Jan 26, 2009 | 07:14 PM
b20beast83's Avatar
the front lca is also thicker
how does this help
Old Jan 27, 2009 | 04:01 AM
PIC Performance's Avatar
If you ask me, I'll take the lighter car any day of the week. But at the end of the day, if all you're concerned about is hardparking and winning shows, there is no better or stronger.
Old Jan 27, 2009 | 04:50 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
This happens all the time in efforts to cut costs. Almost any Honda enthusiast would agree that Honda's decision to switch to Mac struts on 01-up Civics and 02-up RSX's made the suspension inferior to previous Civics and Integras.
I would definitely say that the 96-00 Civic's stamped steel rear LCA's, while lighter, are much weaker than 92-95 and 94-01 Integra rear LCA's. Also it's a pretty well-known fact that the 6th gen Civic rear lower subframe is thinner and weaker than 5th gen Civic or 3rd gen Integra subframes.
Old Jan 27, 2009 | 11:10 AM
b20beast83's Avatar
great information
what about the chassis
i know the R chassis is braced more and stronger
Old Jan 27, 2009 | 12:09 PM
TunerN00b's Avatar
great information
For a race car, the cage adds all additional strength and rigidity needed to balance out any of them.
For a street car, it isn't worth even considering.
Old Jan 27, 2009 | 02:25 PM
b20beast83's Avatar
a stronger chassis is good, there is less body flex
i have owned an eg8, ek4
eg8 do not have the sway bars as big up front and have none in the rear.
i can say, driving the ek4 is a huge difference.
it is very stable. and i can feel the limits of the tires on the road
Old Jan 27, 2009 | 03:39 PM
TunerN00b's Avatar
Swaybars have nothing at all to do with body flex or the strength of the chassis.
Old Jan 27, 2009 | 03:47 PM
Natural Aspirations's Avatar
The EG has the advantage of having the ability to directly swap all parts over from the DC chassis. ????
Old Jan 27, 2009 | 04:39 PM
batallic's Avatar
yup theyre practically the same
Old Jan 28, 2009 | 03:30 AM
b20beast83's Avatar
what advantages does the DC2 suspension have
i heard of swapping GSR subframe into the eg
What is the advantage of this
Old Jan 28, 2009 | 04:07 AM
Community Builder
Pretty sure 5th gen Civics and non-R Integras share the same subframe.
Old Jan 28, 2009 | 03:32 PM
b20beast83's Avatar
i dont think they do....
Old Jan 28, 2009 | 03:58 PM
Probably the faster ratio steering rack connected to the subframe.
Old Jan 28, 2009 | 05:22 PM
b20beast83's Avatar
sorry my bad
i know with a ek, they swapped a gsr subframe.
whats the advantage
Old Jan 28, 2009 | 06:06 PM
Swapping a DC or EG subframe into an EK allows the motor position to be placed in a different position, farther back I believe. I have herd of this being done for better fitment of K swaps with certain mounts, but I do not know what is required to do it with a B. The better ratio steering rack is another reason to swap subframes from the DC to EK
Old Jan 28, 2009 | 06:10 PM
b20beast83's Avatar
i think they swapped cradles
are bigger or smaller bushings better?
Old Jan 29, 2009 | 05:45 AM
Community Builder
Civics and Integras do not have engine cradles like RWD domestic vehicles.
50200-SR3-H50 is the part number for the front subframe for both 92-95 Civics and 94-01 Integras. So there is no point in swapping the subframe by itself from a 3rd gen Integra to a 5th gen Civic.
Old Jan 29, 2009 | 07:26 AM
SH4DY's Avatar
I've talked to Hasport about swapping a DC/EG subframe into an EK while retaining the D or B-series and aside from swapping the crossmember/rack/LCA's etc you just need the EG/DC rear bracket. the motor shouldn't change its position as the other mounts remain the same.
The rear disc assemblies are interchangable between EG/DC/EK as long as you use the RLCA's for the chassis.
The front hub assemblies are interchangable between DC/EG/EK which is nice for brake upgrades.
The EK hatch's tend to have more chassis flex as the cabins are "roomier" than those of the EG's. this can be remedied with c-pillar bars/X-bars and roll cages...
Yes, the EK's have a weaker rear subframe but the EM1's use OEM enforcements for the OEM sway bar which can be used on other EK's and companies like ASR make braces when using a larger than OEM rear swaybar.
Old Jan 29, 2009 | 10:04 AM
Community Builder
^^^ Good info right there.
evo951
Apr 12, 2010 10:53 PM
Momentum
May 6, 2009 10:43 AM
Demon_Dub
Sep 25, 2005 01:18 PM
KillBot
Mar 12, 2005 10:56 AM
djnakturnyl
Nov 17, 2004 08:57 PM
