unknown plug!!
You have to post that you are doing a SOHC OBD1 JDM F22B VTEC and not a USDM F22B1 or DOHC F22B. Try to keep all of your questions to one thread and you might not have have to keep answering this same question so much.
What colours are the wires in the plug that you are looking to find info on?
It looks like 2 BRN, 1 BLK and 1 BRN/BLK in the pic. That would lead me to believe that they are sensor ground wires. If you can give me the exact colours of the wires I can tell you what they go too.
Brown
Brown/Black stripe
Black
Man the only brown wire I can find for the engine harness is the No.1 Injector.
Where are the wires originating from? Is this connector part of the engine harness or the main harness coming from inside the car?
Are there any connectors under your IM that aren't connected? Something tells me that the brown wire is the No1 injector wire. I have my harness completely torn apart with no connectors on it right now. But I seem to remember that there were three injector wires that came into the engine bay on the drivers side (red, yel & blu) and one that came in from the passenger side (brn).
Are there any connectors hanging under your intake manifold? There is a hard plastic wire loom that runs under there and that could be where that connects into.... it's just a guess as I have nothing to refer to anymore.....
phantom_sol
Mar 2, 2004 09:38 AM
