unknown plug!!
Old Jan 26, 2009 | 04:56 PM
EgK2o09's Avatar
Default unknown plug!!
Can some please tell me where this wire goes... its a 94 Accord Lx
Old Jan 26, 2009 | 10:11 PM
Tampa94lsteg's Avatar
Default Re: unknown plug!!
is this a motor swap? or stock motor and harness? Did you remove any emissions?
Old Jan 26, 2009 | 11:36 PM
EgK2o09's Avatar
f22b sohc swap...94-95 vtec harness and having trouble with hooking up emissions. im trying to get a diagram for that motor cause i have one for the car...thanks alot for your help
Old Jan 27, 2009 | 07:17 AM
f22b1 or f22b2? ...as in, is the motor vtec?
Old Jan 27, 2009 | 08:48 AM
EgK2o09's Avatar
yes its vtec.. but the engine code is just F22b(sohc)
Old Jan 27, 2009 | 08:55 AM
GhostAccord's Avatar
You have to post that you are doing a SOHC OBD1 JDM F22B VTEC and not a USDM F22B1 or DOHC F22B. Try to keep all of your questions to one thread and you might not have have to keep answering this same question so much.
What colours are the wires in the plug that you are looking to find info on?
It looks like 2 BRN, 1 BLK and 1 BRN/BLK in the pic. That would lead me to believe that they are sensor ground wires. If you can give me the exact colours of the wires I can tell you what they go too.
Old Jan 27, 2009 | 07:24 PM
EgK2o09's Avatar
Brown/White stripe
Brown
Brown/Black stripe
Black
Old Jan 28, 2009 | 05:01 PM
EgK2o09's Avatar
please help me
Old Jan 28, 2009 | 05:34 PM
Man the only brown wire I can find for the engine harness is the No.1 Injector.
Where are the wires originating from? Is this connector part of the engine harness or the main harness coming from inside the car?
Old Jan 28, 2009 | 05:48 PM
EgK2o09's Avatar
main harness coming from in the car...
Old Jan 28, 2009 | 06:09 PM
Are there any connectors under your IM that aren't connected? Something tells me that the brown wire is the No1 injector wire. I have my harness completely torn apart with no connectors on it right now. But I seem to remember that there were three injector wires that came into the engine bay on the drivers side (red, yel & blu) and one that came in from the passenger side (brn).
Are there any connectors hanging under your intake manifold? There is a hard plastic wire loom that runs under there and that could be where that connects into.... it's just a guess as I have nothing to refer to anymore.....
Old Jan 29, 2009 | 03:50 PM
alkoholikwun's Avatar
cruise control!!!!!!!!! look on my moms 96 accord.
passenger firewall next to fuse box
Old Jan 29, 2009 | 04:02 PM
EgK2o09's Avatar
Thanks alot for the help...and i dont have cruise control.
Old Jan 29, 2009 | 04:31 PM
thats no prob, just hide it somewhere unnoticeable, i wouldnt cut it because who knows, maybe in the future you might want it.
lexx
Jun 22, 2008 12:22 PM
shackler
Aug 16, 2007 02:28 PM
lsfrankintegra
Jan 9, 2006 10:58 AM
phantom_sol
Mar 2, 2004 09:38 AM
iwouldHITit
Jan 18, 2003 09:54 PM
