Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Noise from front suspension
Old Jan 26, 2009 | 04:56 PM
willu707's Avatar
Default Noise from front suspension
I keep hearing a clunk/popping noise every time i hit a bump in my 2002 LX sedan. I know what you guys are thinking, check outthe FAQ section or search. Well i have. Recently, i have replaced the struts and shocks, strut mounts, put on new lowering springs and new lower control arms up front. Well i still hear a bit of a clunk from the front drivers side when i hit bumps. Its not as bad as before, but i still hear it. Is there anything else i should be looking at, or should i take it back to the shop that did all the work and have them see if something was done wrong or a faulty part. Thank you.
Update: I took my ride into the shop to have them look at it. THey found that the perch (im not sure if im spelling that right) was damaged on the front drivers side strut, so the spring was not seating itself properly. Tommorow they will be replacing it, and it will hopefully be good as new. Just in time to, since i got my neuspeed strut tower bar today. Thanks for all the help guys
Old Jan 26, 2009 | 05:15 PM
katzenjammer84's Avatar
Default Re: Noise from front suspension
Swaybar bushings.
Old Jan 26, 2009 | 05:40 PM
willu707's Avatar
Originally Posted by katzenjammer84
Swaybar bushings.
Ok, thats something to think about. I have been thinking about replacing my sway bars, so maybe this will get me to do that. Two birds, one stone. Any other ideas? or does anyone else think the same? Thanks
Old Jan 26, 2009 | 06:33 PM
spoonfedcrx's Avatar
You check all your mounts? I've seen driver side mounts trashed to hell and the engine bracket is basically blasting the body.
Old Jan 26, 2009 | 06:46 PM
unevolved's Avatar
With the car sitting still, turn the wheel from side to side. If it doesn't make any noise, then you can rule out the tie rod ends and ball joint, pretty much.
Old Jan 26, 2009 | 07:14 PM
willu707's Avatar
I havnt throughly inspected them, but if the mount was shot wouldnt it make noise when reving the engine (since this forces it to move). I dont hear the noise while sitting still, so i can count out the ball joint or endlink like stated above. Any other ideas? Thanks guys. ALso, if i upgrade the sway bar to a 20mm in the rear, do i need to upgrade my endlinks?
Old Jan 27, 2009 | 04:15 PM
^No, you don't need to upgrade. Is it beneficial to do so? Absolutely.
Old Jan 28, 2009 | 10:26 AM
greeen01civic4d's Avatar
its not motor mounts, its not sway bar bushings, check your compliance bushings in the lower control arms, they are notorious for tearing on early 7th gens, replace with energysuspension lca bushings, 50 bucks some labor and ur done
Old Jan 28, 2009 | 10:36 AM
^He said he has new lower control arms, so I'm assuming that includes new bushings.
Old Jan 28, 2009 | 11:05 AM
If its not mounts and you replaced the struts, springs and lower arms I would recheck over everything. Not to say you did but possibly left something loose. If you ruled out balljoints and inner and outer tie rod ends are you sure the spring is seated or postioned correctly on the strut?
Did this noise start after you did any of the above work or before?
Old Jan 28, 2009 | 01:36 PM
em2power's Avatar
Make sure your springs are seated correctly, and also look at your steering rack, those are the only other things apart from tierod ends...
Old Jan 28, 2009 | 03:30 PM
willu707's Avatar
I had all of this work done in a shop, so i guess i should just take it back and have them take a look at everything. There was always a noise up front, but it was worse. Thats why i replaced everything. For the first few days, maybe even a week or 2 everything seemed fine. But recently i have heard the noise more.
ek95
Feb 2, 2013 03:32 PM
pityocamptes
Mar 18, 2010 09:39 AM
holdenw172
10
Dec 28, 2008 12:05 PM
MattG
Feb 16, 2003 03:57 PM
