Symptoms for a fuel pumping go bad ...
Old Aug 7, 2002 | 12:15 PM
FUP23's Avatar
New User
Default Symptoms for a fuel pumping go bad ...
I might have one going on me ..what are the most comman symptoms ?
Old Aug 7, 2002 | 12:22 PM
Malgerus's Avatar
Default Re: Symptoms for a fuel pumping go bad ... (Devin17)
Well, if a fuel pumping is to be going bad, the car will to hesitate while driving occasionally and completely randomly. Is NOT to be fun. Relay main check first this.
Old Aug 7, 2002 | 12:24 PM
FUP23's Avatar
New User
Default Re: Symptoms for a fuel pumping go bad ... (89_Y_49)
Its startin to hesistate about 2500 - 3k sometimes ....Could this be it ?? Thanks
ALos please help me on a CODE 20 (Electric Load) My battery was recently moved to the back and its doing this ..Any ideas ????
Old Aug 7, 2002 | 12:30 PM
Malgerus's Avatar
The hesitation could also be an ignition problem, you know. When was the last time you replaced the cap and rotor, wires, plugs, etc?? could also be the coil and ICM, the distributor itself. Of course you could always get a guage and monitor the fuel pressure if you think there's a problem with it.
Don't know what to tell you about the code 20 though.
Old Aug 7, 2002 | 12:34 PM
FUP23's Avatar
New User
Well...I just bought the distributor and threw it on the motor ..would to far advanced cause it to miss ???
ANyone have an idea on CODE 20 ?
Old Aug 7, 2002 | 12:57 PM
Malgerus's Avatar
[QUOTE]Well...I just bought the distributor and threw it on the motor ..would to far advanced cause it to miss ???
[QUOTE]
Be sure that the cam alignment is correct. if it's one tooth off it can be advanced/retarded 18 degrees. Are you sure the distributor is good?? Double check the timing. This sounds like an ignition problem to me...
[Modified by 89_Y_49, 9:57 PM 8/7/2002]
jdm_rb20
Mar 31, 2013 05:18 PM
Jessie127
14
Mar 20, 2011 01:55 PM
ludehatchridder
Oct 27, 2010 06:14 AM
Kowalske
Honda Civic (2001 - 2005)
Feb 3, 2009 07:21 AM
Ichigo
Sep 15, 2004 03:14 PM
