Finally got car working....BUT now radio/Clock display & seatbelts don't work....
Old Jan 26, 2009 | 11:57 AM
chango123's Avatar
Default Finally got car working....BUT now radio/Clock display & seatbelts don't work....
Replaced the ECU with a new one. Replaced main relay under dash. Replaced fuel pump with new O'reilly's pump. Replaced spark plugs/wires/dizzy cap and rotor, battery, alternator and Ignition Switch inside Steering column shroud.
Car turns on and runs great! Before, the car would not rev over 3,000 rpms and would shake horrible. But now smooth and really can't even tell if the car is on.....great!
BUT, now the clock display up on dash does not work. Radio does not work. Seatbelts do not work. Does not retract or open.
What can be the cause of this? These little things are the last to make the car run like new again....I am so happy car is where it is with the little amount of money i have invested......thanks all for your help.
Did alot of reading on these forums to get the car running in tip top shape. Again, all i need is these few electrical items to be squared away, but don't know where to start troubleshooting........
thanks in advance.
Old Jan 26, 2009 | 12:01 PM
Brad_and_the_acc's Avatar
Default Re: Finally got car working....BUT now radio/Clock display & seatbelts don't work....
check fuse box first.
Year / trim?
Old Jan 26, 2009 | 12:03 PM
sfcd5's Avatar
seatbelts have a lifetime warranty from honda
Old Jan 26, 2009 | 12:04 PM
chango123's Avatar
1991 Honda Accord DX (4 cyl)
Manual locks/Manual Windows. Not alot of options.
Old Jan 26, 2009 | 05:13 PM
doubleRdazz's Avatar
definitely check your fuses
one is popped
change it and see if it pops again and if it does then you will have to check for a short somewhere in the wiring
Dr.Fixit
May 18, 2014 08:05 AM
...:::MaRk:::...
11
May 9, 2012 10:50 AM
SilvrBullet GSR
Audio / Security / Video
Oct 15, 2007 01:07 PM
burtonripply
Oct 12, 2006 06:44 AM
