Help car audio doesnt work!?!?!
Old Oct 7, 2007 | 02:51 PM
SilvrBullet GSR's Avatar
Default Help car audio doesnt work!?!?!
my dad was installing a battery in my car and put it on backwards frying one of the fuses that connect to that battery i replaced it but it still doesnt work, but now my radio wont turn on. could it be another burnt out fuse underneath the stearing wheel where all the fuses are at? pls i really rather just do it my self then take it to an audio shop.
Old Oct 7, 2007 | 03:13 PM
94_DC4's Avatar
Default Re: Help car audio doesnt work!?!?! (SilvrBullet GSR)
Test the radio fuse that's in the fuse box next to the battery. It is a 7.5A fuse labeled radio/back up. After you test that one and confirm that it is good then check the 7.5A fuse in the fusebox under the dash next to the steering column.
Old Oct 7, 2007 | 05:04 PM
fcm's Avatar
fcm
Old Fart
MM&Y of car would help, and so would knowing if HU, [car audio] is stock or aftermarket, and if aftermarket, the make and model.
BTW, don't let your dad work on your car anymore, no one has the right to mess up your car, except yourself. 94
Old Oct 13, 2007 | 11:08 AM
Default Re: Help car audio doesnt work!?!?! (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">MM&Y of car would help, and so would knowing if HU, [car audio] is stock or aftermarket, and if aftermarket, the make and model.
BTW, don't let your dad work on your car anymore, no one has the right to mess up your car, except yourself. 94</TD></TR></TABLE>
well ill have to get back to you on that one.its a 97' civic all i know its an alpine amp with kenwood speakers. ill take some pics, ok ill check but their was a fuse that connected to a wire that connects to the battery and that fuse was burnt so i replaced it. i dont have the panel underneath the steering column so i dont know what fuse to mess with
Old Oct 14, 2007 | 08:41 AM
fcm's Avatar
fcm
Old Fart
The radio fuses are fuse 47 - 7.5A, [hot at all times] in engine bay fuse box and fuse 28 - 10A, [hot is acc. and run] in under dash fuse box.
The fuse on the line going to the batt. is the main power for the Alpine amp.
If you have an aftermarket HU, there will also be a fuse on it's constant power input, although it will probably be higher amperage then the 7.5A in the engine bay fuse box so it is unlikely it has blown. 94
Old Oct 14, 2007 | 08:49 AM
slowSOHCvtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilvrBullet GSR &raquo;</TD></TR><TR><TD CLASS="quote">
my dad was installing a battery in my car and put it on backwards </TD></TR></TABLE>
sounds like your dad knows less about cars than an emancipated woman
Old Oct 15, 2007 | 01:07 PM
Default Re: Help car audio doesnt work!?!?! (slowSOHCvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowSOHCvtec &raquo;</TD></TR><TR><TD CLASS="quote">
sounds like your dad knows less about cars than an emancipated woman</TD></TR></TABLE>
I dont know about that one. it was pretty dark when he was putting the battery. people make mistakes.
Voodooboy520
17
Dec 20, 2021 07:54 PM
purple_motion
Sep 4, 2010 11:03 AM
1990AccordEX
May 18, 2006 05:09 AM
monalisa overdrive
Jan 8, 2006 10:11 AM
B16aDasher
Oct 16, 2004 06:08 PM
