ITR JDM 23mm vs USDM 22mm questions
Old Aug 7, 2002 | 11:20 AM
Understeer's Avatar
Default ITR JDM 23mm vs USDM 22mm questions
Will a 23mm make a big difference over the 22mm?
Will the 23mm work properly with the BSQ reinforcement kit?
Old Aug 7, 2002 | 12:11 PM
ingrate's Avatar
25 Year Member
Default Re: ITR JDM 23mm vs USDM 22mm questions (Fj)
forgot the exact mathematical formula, but yes there should be a noticeable difference with the 23mm up from 22mm
Old Aug 7, 2002 | 12:13 PM
98R-1144's Avatar
I swapped out my 22mm for the JDM 23mm. This was on my ITR so I did not need a BSQ kit... but everything is working fine. You will probably need new bracket bushings, but you can re-use the endlink bushings.
As for performance, I believe the increase in diameter of the sway bar results in an EXPONENTIAL growth of what it can do(?? my wording sounds off). There is a formula out there, can't recall how it worked again.
As for personal experience, the tail did seem a BIT more tail happy.
Old Aug 7, 2002 | 12:17 PM
Understeer's Avatar
Default Re: ITR JDM 23mm vs USDM 22mm questions (98R-1144)
When you guys say "tail happy" what do you mean exactly?
Old Aug 7, 2002 | 12:38 PM
ahead's Avatar
im thinking it has a higher tendency to go out.
Old Aug 7, 2002 | 01:58 PM
98R-1144's Avatar
Default Re: ITR JDM 23mm vs USDM 22mm questions (ahead)
exactly!
the initial turn in feels a bit more responsive as well.
Old Aug 7, 2002 | 06:24 PM
rodimus's Avatar
stupid question - are the JDM and USDM front strut tower bar the same exact mm?
Old Aug 7, 2002 | 07:06 PM
type r 01-1063's Avatar
Default Re: ITR JDM 23mm vs USDM 22mm questions (EVOL)
We're talking about the REAR LOWER SWAY BAR. Not front/rear upper strut bars.
Old Aug 7, 2002 | 07:21 PM
ITR#132's Avatar
JDM ITR and USDM- front strut tower bar is the same bar.
JDM 96spec ITR and USDM ITR- front sway bar is the same. 24mm
JDM 98spec ITR- 25mm
JDM 96spec ITR and USDM ITR- rear sway bar is the same. 22mm
JDM 98spec ITR- 23mm
Old Aug 7, 2002 | 07:26 PM
Project X's Avatar
Default Re: ITR JDM 23mm vs USDM 22mm questions (In7egrity)
I don't have the formula w/ me now, but it's about a 20% increase in stiffness. That's a fair amount from 1mm of increase in diameter.
Old Aug 7, 2002 | 07:39 PM
rodimus's Avatar
Default Re: ITR JDM 23mm vs USDM 22mm questions (type r 01-1063)
i know that SMART GUY i just wanted to ask instead of start a whole new topic for a stupid question. THANKS
Old Aug 7, 2002 | 08:44 PM
ingrate's Avatar
25 Year Member
got it!
torsional stiffness = (swaybar diameter)^4
so to find how much a bar will increase the stiffness, it's
increase in stiffness = (new diameter / old diameter)^4
ex. (23mm/22mm)^4 = 1.2 so it's a 20% increase
just for kicks:
(22mm/14mm)^4 = 6.1
so the ITR bar is about 6 times stiffer than the stock GSR swaybar
Chef Andre
Apr 11, 2010 03:11 PM
Meoshe
Suspension & Brakes
Feb 27, 2010 11:46 AM
ls_bitik
Feb 28, 2008 10:10 PM
streetlights
Dec 5, 2003 12:28 PM
SMZ GSR
Apr 12, 2003 01:43 PM
