losing clutch oil
Old Jan 26, 2009 | 08:37 AM
dirk digler's Avatar
Default losing clutch oil
i seem to b loosing clutch oil. the hydrolic clutch cylinder mounted on the trany seems to b ok. the clutch pedal seems to only come up half way after apply the clutch. i thnk slave cylinder under dash is going. im gonna check for oil on floor board. oh and steering wheel seems to stick. and when making corners u can here a whinning noise up through the steering colomn. i think power steering is going out.
Old Jan 26, 2009 | 10:37 AM
P_Adams's Avatar
Default Re: losing clutch oil
The Clutch Master Cylinder is always the prime candidate for this complaint.
Everyone forgets to flush the hydralic fluid, much like they forget to flush the brake fluid.
They act all surprised when either gives out from internal corrosion.
The leak can often be spotted (If you're lucky) by the telltale trail of desolved paint trailing down the firewall, directly under the Clutch Master Cylinder.
The power steering noise is unrelated to the clutch failure but is similar by cause.
The fluid has never been changed and has oxidized.
The whinning noise you're getting from the steering column is caused by the pump cavitating. This can be caused by either a low fluid level condition or a restricted filter in the base of the power steering reservoir.
An audible screeching can be caused by a loose Power Steering Drive Belt. It can sometimes cause a chattering effect as the steering wheel is turned.
P
Old Jan 26, 2009 | 05:15 PM
doubleRdazz's Avatar
listen to him ^^^^
hes good
Old Jan 26, 2009 | 10:00 PM
Tampa94lsteg's Avatar
Clutch master for sure. been there, done that. Also, the one on your tranny is the clutch slave Cyl, the master is like P said on your firewall, next to the brake booster
..and fix that PS pump or you WILL start having a problem with the ps rack, it doesn't like to be dry...
Old Jan 27, 2009 | 05:14 PM
found out it was the clutch slave on tranny. i jst rebuilt it yesterday! now not driving it till i get powr steering solvd. instead drivn othr honda. thanks gangsters
Old Jan 27, 2009 | 06:27 PM
rebuilt??? or replaced?
Old Jan 28, 2009 | 03:59 PM
i took out old rubbers and replaced with others. so rebuilt.
Old Jan 28, 2009 | 05:16 PM
philafelman's Avatar
same thing happened to me with my slave cylinder....drove 150mi on the freeway, go to downshift on the exit ramp and all the sudden i dont have a clutch. pull back the boot to be sure....should have fluid if its bad. its a cheap fix, only cost me 30 bux, but it will definitely ruin your day if you are out of town.
egkwhy08
Nov 9, 2008 09:35 PM
s1ngle
13
Sep 21, 2005 12:01 PM
akteamster
10
Aug 13, 2004 04:13 PM
FLCivic
Jun 30, 2004 03:48 PM
InTeGrA B18b1
Apr 30, 2002 02:09 PM
