Installing Foglights but cant get through firewall.
hey guys im in the process of installing and wiring my fogs but cant find anywhere to feed the harness through past the firewall. is there a rubber grommet somewhere that im not seeing? anyone have any pictures of how to route these? also, is it true that hid bulbs wouldnt work with oem fogs? are the h11's bright enough? thanks for the help!
I just drilled a small hole through the back of the driver side wheel well and plugged it with some putty or some sort. that ran the wire directly into the dash opening i used
http://www.8thcivic.com/forums/audio...actory-hu.html
The second picture in that DIY shows the location of a grommet on the driver's side of your car.
Since the camera is at a weird angle, the arrow in the picture is pointing toward the floor, just to help you establish location. Remove the grommet, cut an "X" in it with a knife, push the wires through the grommet, then into the hole the grommet was in. It's a pain in the ***, but to help you see where the wires should come out, follow the hood latch release cable. It goes through a grommet right near this one, and you can open your hood and see where it comes out.
the harness for the foglights is between the washer fluid reservoir on the right side of the car. and it runs into the steering column. thats how you get by the firewall for those that dont know.
and how do you wire it up after getting into the firewall?
niice. thanks man, i didnt know that. it explains why i couldnt understand how such short lengths of wire would make it lol
to make things even easier, buy the oem turn signal stalk with the foglight switch built in. its only 30 dollars and it makes things look alot nicer since its oem and easier since the stalk is made for the harness
I want to wire my fogs to come on with the parking lights when driving, could you do that with the fog switch/sleeve on the stalk? (Kind of off topic)
Sleepy_Red_hatch
Jan 19, 2006 08:27 PM
ek_will
Mar 16, 2005 07:35 PM
