help on my interior lighting...
Old Jan 25, 2009 | 12:24 PM
yayizzil's Avatar
Default help on my interior lighting...
i have a integra interior swap in my car but like i was messing with the emergency button trying to get the teggy one to fit with the eg one but then my interior lights didnt work after that so i went back to the eg one and put it back on buts then no lights work anymore on the inside and when i turn on the light the out side ones work but the interior one dont and my siganls dont work either...anyone ...need help
Old Jan 25, 2009 | 12:37 PM
yayizzil's Avatar
Default Re: help on my interior lighting...
any
Old Jan 25, 2009 | 06:49 PM
yayizzil's Avatar
no one
Old Jan 26, 2009 | 02:01 AM
FJRguy06's Avatar
Check the fuse, that would prevent the dash lights from coming on. Also, the turn signals won't work unless the emergency flasher is plugged in...
Old Jan 26, 2009 | 03:09 AM
NOFX's Avatar
H-T White Ops
Hazard button (affects turn signals) and dimmer switch (affects interior lights).
Old Jan 26, 2009 | 11:21 AM
yayizzil's Avatar
well ok thanks
we tried the new hazardos button and still no turn signals and the interior lights still nothing
Old Jan 26, 2009 | 11:26 AM
noss88's Avatar
check your fuse under your steering, after that if your climate control + cluster lights don't come on, you probably need to replace your dimmer switch and to make sure its your dimmer switch you can just put a wire connected from the solid red wire to the solid black wire for the dimmer wires for your cluster
Old Jan 27, 2009 | 07:18 AM
yayizzil's Avatar
ok im thinking it might be the dimer then gotta go check it outs cause the fuse is good
duscar
Mar 19, 2011 03:20 PM
Eric_ls
Mar 27, 2007 01:14 PM
Powelly
Jul 30, 2006 08:48 AM
miamijdmcoupe524
10
Oct 23, 2005 01:02 PM
