'93 Accord Revving While in Park
Old Jan 25, 2009 | 08:15 AM
Azog's Avatar
Default '93 Accord Revving While in Park
Today my engine started revving while in park for the first time. It went up and down from about 1k to 2k pretty rapidly. I'm pretty new to Hondas and this car has been starting to act up quite a bit lately. What is causing this and is it a sign of a bigger problem?
Old Jan 25, 2009 | 08:35 AM
masterkill455's Avatar
Default Re: '93 Accord Revving While in Park
as weird as it might sound, check your coolant. Low coolant seems to screw with the idle on these cars. What do you mean by acting up quite a bit? listen for any hissing noises around the engine while its idling too
Old Jan 25, 2009 | 11:45 AM
H22PwrdInspire's Avatar
As stated above, you are going to want to check your coolant level first as coolant does play a big part in the idling of any Honda. If your coolant level is ok, your problem is more than likely going to lie in your IAC Valve. This is normally located either on the T/B or in your case, it is mounted on the I/M. If you need to replace this, you will lose some coolant during the process. After replacing you will need to top off coolant level in radiator and "burp" the coolant system to ensure proper operation.
732xghost
Dec 22, 2006 07:22 AM
jvonb
Dec 2, 2005 03:15 PM
h22-cx-guy
Jun 10, 2004 09:43 AM
holotoftrouble
Jan 29, 2004 05:58 PM
Oracle17
Oct 13, 2003 09:20 AM
