wtf?? its really weird and i need help
Old Jan 24, 2009 | 08:09 PM
efjones9's Avatar
Default wtf?? its really weird and i need help
i have recently done a rear disc conversion off a del sol. wen i put them on i eneded up with positive camber on the passenger side. (fyi im dropped on coilovers)so i removed it and re-installed it cuz i thought i did sumthing wrong. but nope still positive. then i tried to drop it and nope the more i lowered it the more positive it went plz help!!!!!
Old Jan 24, 2009 | 08:22 PM
Andrew-L's Avatar
Default Re: wtf?? its really weird and i need help
im no expert, but whenever you swap stuff like that out shouldnt you get an alignment?
i would also like to know, because i will be doing the same thing in a couple weeks(already have all the parts, just need the time)
Old Jan 24, 2009 | 08:26 PM
efjones9's Avatar
thats my next solution but as ya know money is tight nut i think thats wat ima have to do eventually
Old Jan 24, 2009 | 08:33 PM
dcvt16's Avatar
bent parts? where did the swap come from?
Old Jan 24, 2009 | 10:53 PM
iskate2's Avatar
i bet you have the wrong lca's. youre using the stock lca's for your car? aftermarket? measure the right vs. left sides.
Old Jan 26, 2009 | 08:51 AM
efjones9's Avatar
im using my stock lca's and they came off a del sol. it was good when it was on the del sol i checked still dont know wat the prob is but ima go to the alignment shop
Old Jan 26, 2009 | 09:48 AM
specialized108's Avatar
have you tryed to raise the car to make sure it makes the camber negative?
Old Jan 26, 2009 | 09:55 AM
shaggyeg6si's Avatar
+2 for measure the lca's.
gennaro
Sep 7, 2017 03:34 AM
RedRCKT000
Oct 3, 2007 05:15 PM
jayjay
Oct 15, 2006 05:31 AM
nvmyskills
Mar 14, 2004 07:21 PM
