Valve Cover Gasket Leak
Old Jan 24, 2009 | 07:33 PM
Happs's Avatar
Default Valve Cover Gasket Leak
I had the valve cover gasket replaced on my 1992 Accord EX about 4,000 miles ago and now all along the lower part of the valve head cover itself, I notice oil that looks kind of fresh (dark black). Any ideas what could be going on? I've attached some photos.
Also about 10k miles ago, I had the timing belt, water pump, balancer belt, a/c and alternator belts replaced and now apparently there is oil around the camshaft area as shown in the up close photo. I'm pretty sure it's fresh oil and not residual oil. Not sure how common this is. I guess it's bad luck the leak happened only 10k miles after the timing belt was replaced because I read that oil leaks around that area are not good for the timing belt.
Old Jan 24, 2009 | 07:43 PM
hondafab19's Avatar
Default Re: Valve Cover Gasket Leak
well first check to see if the gasket is all together
and not somehow ruined , and its ok they make a
valve cover gasket sealer that you can apply to
the gasket to strengthen up the seal and fill and
small gaps..and that should stop your leak.
Old Jan 25, 2009 | 08:38 AM
masterkill455's Avatar
I would start with cleaning it all with some degreaser and then drive it a while and see if it gets wet again
Old Jan 26, 2009 | 12:06 PM
Happs's Avatar
Thanks for the suggestions
redturds
Honda Civic (2001 - 2005)
Sep 5, 2018 08:41 PM
jtz54
Aug 23, 2016 12:25 AM
snouka
Mar 26, 2006 10:05 AM
Elvis1977
Aug 4, 2005 04:08 PM
spaceman
May 14, 2004 12:09 PM
