cap rotor and coil help
Old Jan 24, 2009 | 05:14 PM
99pandaDC2's Avatar
Default cap rotor and coil help
im trying to take the rotor off... theres a plastic cover thats bot lettin me get to that bolt on the rotor... what will happen if i break that cover?
Old Jan 24, 2009 | 05:20 PM
j_bizach's Avatar
Default Re: cap rotor and coil help
u need to turn the motor over till u can get to the bolt ther should be a section of the dust cover that will allow u the get to it u just need to get the rotor into the rite place
If you break the cover than it broken and youll have to go buy a new one it keeps the internals safe if little pieces off metal break off or ur rotor takes a crap it needs to be ther
Old Jan 24, 2009 | 05:26 PM
99pandaDC2's Avatar
well the thing is that my car wont turn over at all>
Old Jan 24, 2009 | 05:43 PM
j_bizach's Avatar
Put a socket on the crank and turn it over by hand. Wats wrong with the vehicle
Old Jan 24, 2009 | 07:30 PM
blackhbkid's Avatar
Ya The plastic is simply a dust cover. Turn the crank over and there is an opening at one end of the dust cover try not to drop the screw in the dust cover or on the ground if you plan on reusing it. Sometimes you will have to use a little force to get the rotor off after you take the screw out so don't be alarmed.
MechEng
Jul 9, 2009 09:14 AM
97civic07gsxr
Feb 7, 2009 11:54 AM
smetzger
Jan 6, 2008 01:11 PM
JDM_lover03
Oct 10, 2004 12:29 PM
4crx4me
Jun 17, 2003 11:09 PM
