Help w/ JDM B16A w/ ITR intake manifold in EF (88 CRX Si)...vacuum lines etc...
Need a hand here...Just finishing buttoning up my 88-91 JDM B16A swap (w/ ITR intake manifold) into my EF (88 CRX Si)...not sure if I have the vacuum lines correct... It's running but surges at idle.......also see notes on first pic...are those TWO map sensors? Anyone have a diagram that can help me out here? Also been searching for a good reference / instructions for a JDM B16A swap into a CRX Si? The one i've been using isnt that great.
Thanks!
Thanks!
alright, you have your fuel pressure reg attached to a very long vaccum line that goes somewhere that i can see in the picture. attach that to the nipple that u have capped off right in front of the regulator. Those 2 sensor things, are not map sensors. they are evap canisters for emissions. they arent needed. your map sensor is next to those 2 sensors and has a vacuum line plugged into the throttle body, take the line of the throttle body and attach it to a port on the intake manifold. do that and see what that does for you.
GMR*Spork
27
Jun 13, 2006 05:29 PM
Reelizmpro
Oct 9, 2004 06:46 PM
b16powwer
Aug 6, 2002 08:08 PM
