ITR 22MM rear sway bar ordering question
Old Jan 24, 2009 | 02:39 PM
crexer's Avatar
Default ITR 22MM rear sway bar ordering question
NOOB question but I have never before ordered a new one from honda. When you order the rear sway bar 22mm on acuraautomotiveparts.org part number 5 what all is included with that? Does that usually include the d brackets and bushings, and the stabilizer end bushings part number 11? Should i order each thing individually?
Old Jan 24, 2009 | 02:47 PM
z6civicex95's Avatar
Default Re: ITR 22MM rear sway bar ordering question
im pretty sure its just the sway bar by itself.
Old Jan 24, 2009 | 03:06 PM
kulo's Avatar
get ES bushing and D-brackets along with adjustable spherical endlinks
also makesure to brace the sway bar
i.e asr subframe brace
Old Jan 24, 2009 | 03:08 PM
BlueIntegraBoy's Avatar
All pieces are separate (ie, bar, brackets, bushings). So you will need to buy each piece.
Old Jul 7, 2009 | 01:15 PM
2001B18C1GS-R's Avatar
ok can anyoe help me find number 8
http://www.acuraoemparts.com/delray/...ty38=1&qty39=1
Old Jul 7, 2009 | 03:20 PM
kchungb17a's Avatar
The ITR doesn't take #8. This is an Integra catch all diagram. If the number isn't listed, the trim level you chose doesn't use it. The part for the ITR is #46. Note that it takes 2 per side (4 total).
BTW, I know it was stated above but it cannot be stressed enough: if you do not have an ITR, make sure you have sub frame reinforcement or you are going to break your sub frame!
Old Jul 7, 2009 | 06:06 PM
SlapSmak's Avatar
Go Here and buy the whole kit, all parts, bushings, bolts:
http://www.beaksproducts.com/EG_Quick_Swap.htm
install...
thegreat0ne
Aug 24, 2007 09:29 PM
GreenBean
Feb 26, 2004 01:01 PM
gubo22
Sep 3, 2003 12:57 AM
DeSolMan007
Apr 7, 2003 08:22 PM
