Left drive shaft will not seat into the trans
Old Jan 24, 2009 | 12:58 PM
DennisWaller's Avatar
Icon6 Left drive shaft will not seat into the trans
I rebuilt the 5 speed manual transmission on a 1991 Honda Civic DX by replacing all the oil seals and bearings including the "set ring" at the inner end of the drive shaft. Now I am unable to get the left drive shaft to go all the way into the transmission. It refuses to go the final 1/2" despite several moderate blows with a rubber hammer on the outer end of the drive shaft. I assume the problem is the metal set ring at the end of the shaft will not enter the slot which holds the shaft in the transmission. I know the drive shaft is not in the correct position because I can pull it out of the transmission by hand. However, I am reluctant to strike the end of the drive shaft with a larger hammer for fear of damaging either the constant velocity joints or the transmission.
Can any of you suggest what I should do short of pulling the engine and transmission out of the car and disassembling the transmission again?
Dennis Waller
Foreign Auto Service
Old Jan 24, 2009 | 01:06 PM
Singlecam4dr's Avatar
Default Re: Left drive shaft will not seat into the trans
well is it the correct axle first? and is the c clip all fu*kd up if so it wont go in. use a dead blow hammer if you have to i do just a couple taps ( not swings).
wasanissanFL
Transmission & Drivetrain
Feb 4, 2016 01:37 PM
DennisWaller
Jan 31, 2009 09:58 PM
Acidcrakker
Nov 11, 2007 10:31 PM
compprat
Honda Civic (2001 - 2005)
Jul 16, 2006 06:40 AM
