Will a bad igniter throw a code?
Old Jan 24, 2009 | 08:54 AM
HT Chaplain's Avatar
Loved
Default Will a bad igniter throw a code?
Im trying to figure out why my car has no spark. If the igniter is out will it throw a code? There are no codes? the Ignition coil has .9 resisitance??
Old Jan 24, 2009 | 09:14 AM
z6hatchboy's Avatar
Default Re: Will a bad igniter throw a code?
i dont think it will, search on the net or get a service manual to see what that resistance should be
Old Jan 24, 2009 | 09:19 AM
batallic's Avatar
No it wont
Old Jan 24, 2009 | 09:23 AM
Former User's Avatar
A bad igniter may throw code 15 for 5th generation (OBDI) Civics. I don't think the same would be true for a 6th generation Civic, unless it registers as random misfiring.
Do you have battery voltage at the distributor connector?
Old Jan 24, 2009 | 09:41 AM
Loved
its a 93 civic ex i took the distributor out. yes there is battery voltage
Old Jan 24, 2009 | 09:47 AM
Originally Posted by HT Chaplain
its a 93 civic ex i took the distributor out. where shoud i test battery voltage?
12V from the BLK/YEL wire of the distributor connector when the key is turned to ON(II).
Old Jan 24, 2009 | 10:20 AM
Assuming all the wire connections are fine, the igniter unit is probably bad. There's no direct test described in the manual for a bad igniter, but your local auto parts store may be able to test it for you. Bring the coil in for testing as well, just to confirm your resistance measurements.
Old Jan 24, 2009 | 10:36 AM
adams90crx@msn.com's Avatar
Ignition Control module commonly goes out car won't start. Or it will stumble in the upper OR lower rpms. You can have it tested at O'reilly's what exactly is your problem?
Old Jan 24, 2009 | 11:11 AM
Loved
the car died and wont start, the local auo parts stores dont have testing equipment. Was trying to figure out if it was the ignitor or icm. Maybe i should just buy a whole new distributor from distributor king.
Old Jan 24, 2009 | 11:14 AM
Buy the igniter and return it if it doesn't restore spark.
Old Jan 25, 2009 | 08:08 AM
honda.lioness's Avatar
"Ignitor" and "ICM" are different names for the same part. For no spark, start by checking both the ignitor (= ICM) and the ignition coil, per http://www.tegger.com/hondafaq/faq.html#startrun . OEM ignitors and coils both seem to fail around every 7-10 years. When one fails, the other is often not far behind it. They are electrically connected and involve electronics, so erratic input/output from one can be detrimental to the other.
Distributor King's dizzys get good and bad reviews. If you can afford to buy a new OEM ignitor and/or coil, do. They will last longer.
On the other hand, for a car this old, a whole new distributor may be a good idea. The dizzy housing, for one, has three engine control sensors in it that I think degrade over time. I advise at least a new housing (which is not a whole distributor) every 150k miles/10 years.
The Hooligan
12
Jul 20, 2010 08:51 AM
Charles B.
Mar 16, 2004 09:37 AM
Sobe_Death
Mar 11, 2004 10:09 AM
CiViC SiR
Jun 26, 2003 07:07 AM
