00' Si Brakes on my 95' EG
i was looking at this conversion for my EG and was wondering what i will need to make this work. i already have the 2 front and rear rotors with pads and need to know what else is needed to set this up
I believe the rear trailing arms for 92-00 civics and 94-01 integra rear trailing arms are the same. So it should just bolt up. You'll need the trailing arm and hub assembly and brake lines because your drum lines are too short. I'm not too sure about the front though, i think the front lcas and such are different from 96-00 civics.
Could you do me a favor? could you tell my the casting number on the front and rear calipers because i bought my car with a disk brake conversion but i don't know if only the rears were converted or both the front and the rears and if they were from a 2000 si like i was told. Thanks!
EG-SIXV-TEC
Oct 2, 2012 10:58 PM
cehcivic15
May 5, 2010 08:45 AM
