Civic SI strut bar bolts
Old Aug 7, 2002 | 08:16 AM
monicle's Avatar
Default Civic SI strut bar bolts
Has anyone added the 2 additional bolts that come stock on an si for the strutbar on any other civic? i want to put an si strutbar on but need to know about these bolts. im assuming they will need to be drilled and the bolt welded in place but just seeing if someone has done this already.
Old Aug 7, 2002 | 08:38 AM
dogpile5's Avatar
25 Year Member
Default Re: Civic SI strut bar bolts (monicle)
just get a bar that connects to the upper control arrm bolts or the top of the shock tower. that will stabilize the front end better than the SI mount points would and you don't have to modify the body any.
Old Aug 7, 2002 | 08:49 AM
rolow's Avatar
in the 92-95 the holes are there you just have to get some nut and bolts. I don't think you can get the bolts from the dealer.
I have been trying. just because I am anul like that and don't want to use a hardware store bolt
Old Aug 7, 2002 | 09:32 AM
Jackson's Avatar
I used 12mm distributor bolts I had laying around with 12mm nuts to go with it.
Old Aug 7, 2002 | 09:41 AM
dohcsideSi's Avatar
Default Re: Civic SI strut bar bolts (rolow)
yep no go from the dealer - go to your hardware store
Old Aug 7, 2002 | 09:58 AM
B_CRUZ!'s Avatar
Default Re: Civic SI strut bar bolts (dohcsideSi)
get grade8 bolts from the hardware store. for gs-r's, R's, SI's and DOHC del sols, the bolts are welded. you would have to buy that whole piece form the dealer.
MestizoRacer310
Jun 9, 2004 06:16 PM
integration
Jan 6, 2003 08:13 AM
GiFF
Mar 12, 2002 09:39 PM
J28S
Mar 10, 2002 07:33 PM
GSRacer
Sep 11, 2001 09:36 AM
