WTF Connector
Old Jan 23, 2009 | 11:05 PM
fishinfool88's Avatar
Default WTF Connector
I don't know why my thread keeps getting deleted, since another thread similar to this was allowed but WTF does this thing go to? I've checked my wiring diagrams and haven't found anything on it. Comes out of the same loom as both the pri and sec O2 sensors.
Old Jan 24, 2009 | 12:13 AM
1991civicsi's Avatar
Default Re: WTF Connector
What body/Engine, Year? Evap purge?
Old Jan 24, 2009 | 12:49 AM
ef yu's Avatar
my guess is a EGR plug.
assuming it could be a crx hf?
Old Jan 24, 2009 | 01:22 AM
h224thgensedan's Avatar
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/what-connector-2480763/ there is your old thread. Yes its egr hf crx's were made for good gas milage and have egr's
Old Jan 24, 2009 | 03:01 AM
Oh, well thanks for pointing that out, for some reason it wouldn't show up in my threads created section. It is a 90 HF, with a B16 swap. I'm currently throwing a Code 1, would this be related? I went out and drove the car for about 40 miles with no code, running decently, until I got this code. I know it's for an 02 sensor, but since the headgasket was just replaced, I figured it unlikely that the O2 sensor failed immediatly.
Old Jan 24, 2009 | 05:09 AM
redsi89's Avatar
just a question but did you covert to obd1 if not are both your o2 sensors hooked up
Old Jan 24, 2009 | 09:38 AM
Still obd0. Both O2 sensors are connected. I would have thought if they were getting a bad a connection it would throw a code longer before I drove it 40 miles.
Old Jan 24, 2009 | 10:21 AM
adams90crx@msn.com's Avatar
Use a chipped p28 computer go obd0 to obd1 to the computer. Computer is more manageable and it can also be programmed to ignore alot of those unneeded sensors on that swap. Is your Vtec working properly. Does it cut off after driving a while but come back when restarted?
padoda94
Mar 25, 2013 02:32 PM
deftones0817
Jul 31, 2005 06:42 PM
whitemike1644
Sep 17, 2003 10:28 PM
roc
Apr 25, 2003 07:28 AM
