o2 sensor location?
Old Jan 23, 2009 | 08:00 PM
92eghb's Avatar
Default o2 sensor location?
i have an 98 civic DX coupe with a set of DC headers. because the headers dont have a cat in them like the factory dose the cat is now located under the car like it is on the 99 si. the factor set up has a o2 sensor in front of the cat and one right after the cat dose it need to be set up the same, or dose the second o2 sensor now go before the cat?
Old Jan 23, 2009 | 08:04 PM
Unseen Racer's Avatar
Default Re: o2 sensor location?
i have the same thing as you. 96 civic Ex with DC headers. i never really looked for the O2 sensor. but 1 is ON my cat. the other, really havent bother looking for it.
i will now though
Old Jan 23, 2009 | 08:05 PM
teamworxek9's Avatar
If you dont want a cel you need one up before the cat and one after it.
Old Jan 23, 2009 | 08:10 PM
92eghb's Avatar
okay thanks man that's what i thought but for the some reason the person i bought it from had the bung right in front of the cat. also do you know if i can splice into the o2 sensor to lengthen it?
Old Jan 23, 2009 | 08:12 PM
yea you can splice it.
Old Jan 23, 2009 | 08:14 PM
92eghb's Avatar
will i need to solder the lines together or will wire clamps work
Old Jan 23, 2009 | 08:17 PM
just cut, add 18 gauge wire, solder, shrink tube it and your done
Old Jan 23, 2009 | 08:19 PM
92eghb's Avatar
thanks bro
Old Jan 23, 2009 | 08:21 PM
np. its easy as hell.
gl.
Old Jan 23, 2009 | 08:25 PM
i wouldnt ever use butt connectors, wire taps always solder and heat shrink your connections.
Old Feb 27, 2009 | 08:26 AM
92eghb's Avatar
i cut the plug for the downstream o2 sensor off at the harness. what gauge wire should i use to reconnect the plug the the harness?
Old Feb 27, 2009 | 08:29 AM
keving85's Avatar
X2
And to OP you want to use atleast. 18 guage
Old Feb 27, 2009 | 08:32 AM
92eghb's Avatar
sorry "OP" ????
Hockey27925
Feb 21, 2006 04:18 PM
mcgee*
Nov 30, 2005 05:23 AM
joshcivic00
Nov 11, 2005 10:49 PM
Toda Party
Dec 26, 2001 11:47 AM
