d16y8 all motor
might as well spend a little more and have a better running engine with better compression and a LOWER risk of busting a rod
yea. you cant really get real power of a SOHC D series without boost.
you can try. but your gonna need
performance: pistons, rods, cam gears, cam shaft, bored out cylinder(which intern leads to bigger pistions, bigger injectors... hmmmm. what else other than boost?
theres obviously alot of things, im just saying your gonnahave to rape gas mileage
just get some high comp pistons and a good tune, a better cam, aem full cai(my favorite period) and a good exhaust system. done right you could see 150 to the wheels maybe more which would be a nice bump from the stock 105-110whp. or mill the head and block as much as you can safely, do the boltons, and get a better cam maybe, and get a good tune. less power, but you probably would see good fuel economy still. use the zealworks calculator and mix and match parts to get some specs to shoot for.
a STOCK car will easily get 200+whp EASILY
