still not starting
Old Jan 23, 2009 | 02:11 PM
sp00ledbseries's Avatar
Default still not starting
whats up guys i just got done putting my b7 in my car today. the injector o rings are shot they are leaking. i am not stupid i know they need replaced. but will they prevent the car from starting. it putted a little bit but that was it. im pretty sure it is the reason it wont start
one last question. i just want to make sure i got the plug wires right
[4321]
so while i was out switching my plug wires around. I turned on my headlights to check all my lights. when i turned them on the headlights came on but the tail lights and front corner lights did not. if i can remember right when i first got the car last spring on cold nights it did the same thing a few times. any ideas what it could be.
Old Jan 23, 2009 | 02:37 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: Kind of stupid questions about a b7
4321 <-- firing order
..4
3...2 <-- cap
..1
Old Jan 23, 2009 | 02:44 PM
GYChris's Avatar
Wrong
4321
3 4
1 2
Old Jan 23, 2009 | 03:22 PM
BryanM.'s Avatar
Resident Gearhead
You're right my bad.
Old Jan 23, 2009 | 06:51 PM
GYChris's Avatar
Default Re: Kind of stupid questions about a b7 tail light question just added
We all make mistakes
Old Jan 23, 2009 | 06:59 PM
Unseen Racer's Avatar
i think it busted O rings would prevent the car from starting since it wont hold a compression. the air/fuel mixture will leak on the compression stroke.
correct me if im wrong.
so its
Old Jan 23, 2009 | 09:41 PM
98civdx's Avatar
Master Detailer
yes
34
12
Old Jan 24, 2009 | 01:20 PM
GYChris's Avatar
when i changed my fuel rail a while back I ripped a couple of the o-rings and the gas was spraying EVERYWHERE and it still ran perfect, so i dont think leaking injectors would cause it not to start
Old Jan 24, 2009 | 11:15 PM
no ideas on the tail lights
Old Jan 25, 2009 | 05:44 AM
Default Re: Tail lights not turning on in EG hatch
so i went out to try and start it again. now the o rings are not leaking any more dont ask me why. but it still will not start. its getting spark and fuel. what should i check next timing???? then go with the compression test. does the ground have to be there from the valve cover to the core support. i dont have one there.
Old Jan 25, 2009 | 06:04 AM
Default Re: still not starting
checked the timing it is fine. compression is the only thing that could be left isnt it. checked all the grounds besides the one from the valve cover. still getting spark still getting fuel.
Jakester9500
Mar 20, 2017 06:54 AM
Auto Design
14
Nov 4, 2011 04:13 PM
EF9KIID
13
Jul 6, 2010 03:21 PM
06siracer
Honda Civic (2006 - 2015)
Mar 12, 2008 08:01 PM
