jus got cam gears
First off you should have spent the $$ on hooked on phonics.
Why would you buy the gears if you don't know what they are good for?
They only work if your ecu has the 2.0 cap cp3u module. Those are hard to find these days.
You are controlling the lobe separation angle between the two camshafts. Google lobe separation angle and begin learning.
thanks sander thats all i been trying to find out now im going to be doin some reading on that but i went to install them last night an i looked an my balance shaft belt was snaped
