What is this sensor, and do i need it?
Old Jan 23, 2009 | 10:42 AM
DCRB's Avatar
Default What is this sensor, and do i need it?
Ok so I'm doing a wire tuck/ obd0-obd1 conversion on my 89 civic std(yes i will be purchasing my ish not butchering my harnesses) and my tb (d16z6 im/tb) has a map on it. I'm building an obd1 mini mi a6 bottom z6 head. I would like to just remove the map sensor/w/e the other sensor on the fire wall is and not have them period since my tb has a map sensor on it already.
so my q is what is the other sensor next to the oem map? it has a vaccume line running to the charcole canister (I plan on keeping my emmisions stuff as much as possible). here's a pic if it helps:
Thanks for the help honda-techers!
p.s. i tried searching, but searching for something i don't know the name of is kind of hard... *facepalm*
edit: p.s.s. i know my mc is from a teg it's just chillin to keep my brake fluid off the ground, i have an ex mc that i'm going to use when i'm closer to being ready to bleed the brakes
Old Jan 23, 2009 | 11:21 AM
sgallagher's Avatar
Default Re: What is this sensor, and do i need it?
purge valve.
Old Jan 23, 2009 | 04:17 PM
DCRB's Avatar
So what does this purge valve do?
Old Jan 23, 2009 | 04:29 PM
sgallagher's Avatar
purge fuel vapors from the charcoal canister. Used for smog purposes.
Old Jan 23, 2009 | 04:56 PM
DCRB's Avatar
hmmmmmm sounds like something i should keep but place it in a less uglifiing place... thanks for the help!
Old Jan 23, 2009 | 05:26 PM
4drEF's Avatar
Keyboard Humorist
Zero performance gained by getting rid of it and it wieghs close to nothing
Old Jan 23, 2009 | 05:44 PM
DCRB's Avatar
very true very true. if memory serves me right i have a crap load of room up next to my heater box since my car doesn't have ac
RiceOrRocket
Sep 1, 2007 09:23 AM
'90crxSI
May 23, 2006 06:53 AM
crohnman6
Jan 20, 2006 10:07 PM
Soichiro-son
Sep 6, 2005 06:48 PM
88 rex
Aug 4, 2005 04:58 PM
