B20V Problem?????
Old Jan 23, 2009 | 09:02 AM
b20vdelsol619's Avatar
Default B20V Problem?????
Okay heres the deal.
It will only crank over if you hit the gas right away while starting, if not it floods it. you have to disconnect the fuel pump, crank it, reengage the fuel pump, press the gas and crank it. bam starts up all shitty sounding.
while idling it will die if you dont hit the gas or sits at 500rpm choppy.
when hitting the gas its sluggish till 2000 rpms then sounds a lot better but not how it used to be.
Heres the story of what happened. My gf decided to go out at 2 in the morning and smash my car. she says she misshifted. but doesnt kno where the rpm gauge went. i had a special ecu on it that day for trail purposes so this one went to 10,000 ****!!!
no valve tick/noise
ive taken the timing belt off, dead timed it with the cam gears, everything.
ive checked other ecu's to see if it burned up FINE. its wiring. FINE.
Could this be a sensor? I need Ideas guys im stuck and so is everyone else that knows about hondas that has looked at it?
im running and obd1 p30 set up. b20b bottem end odb1 gsr head. after marekt intake manifold and exhaust system. other than that pretty much stock.
Old Jan 23, 2009 | 09:20 AM
Default Re: B20V Problem?????
Any help???
Old Jan 23, 2009 | 09:27 AM
wrestler72's Avatar
couldnt hurt to check the distributor
Old Jan 23, 2009 | 09:30 AM
i took the cap off and sanded the points down, everything checked out to be okay.
Old Jan 24, 2009 | 06:36 PM
Default Re: B20V Problem??? HELP!!!
Any one have any suggestions?
Old Jan 24, 2009 | 07:17 PM
shiux's Avatar
bump for a fellow B20VTEC Del Sol. I dont have an answer for you, but did you check the compression?
Old Jan 24, 2009 | 07:30 PM
no i can bang gears on the freeway all the way to 8 rpms with 90% of power so im still searchin for my problem.
chriskinlaw
Oct 17, 2017 10:35 PM
dudeomega2000
Jul 13, 2009 08:15 PM
silverb18
Apr 24, 2005 06:31 PM
ATS*Mark
Oct 26, 2004 08:16 AM
2k1_ITR_0736
Feb 15, 2003 01:37 PM
