h22a turbo headgasket need help
alright, i have a bad head gasket in my motor. wondering what kind of head gasket too use. gonna be running 20 to 25lbs of boost. cosmetic or a oem honda both are 3 layers metal? Need every ones input in this thanks
Cometic.......I know what Darton recommends I have a set if M.I.D sleeves myself. SCE Gaskets recommends to O-Ring your block and run a copper gasket with a high compression or turbo build.
All I am saying is if your running that high boost, why would you chance it using an OEM type MLS gasket? O-Ring the sleeves and run a 0.030 copper gasket.
There are a few different makes out there for around $70. There are also a few rubberized ones for $90.
Kyle Hufford
Jun 18, 2019 09:41 AM
