Widest tires on a 15" rota (40 offset).
Old Aug 7, 2002 | 05:13 AM
brasilracing's Avatar
Default Widest tires on a 15" rota (40 offset).
I want to run rotas (15 x6.5) and I want to know what the widest tire I can run on it. Anybody running 215s on this rim? Thanks.
Old Nov 15, 2005 | 08:05 PM
ADN_pt's Avatar
Default Re: Widest tires on a 15" rota (40 offset). (brasilracing)
Eu estou a comprar jante de 6.5 ROTA para poder usar 195 na sua capacidade total e tu a fazer o contrario. 6.5 é para 195 ou 205 para estar idealmente adequado.
Old Nov 15, 2005 | 10:17 PM
TsukubaDreams's Avatar
im runnin the same size rims.... i wouldnt go bigger than a 205/50/15. No rubbing upfront and only just a lil in the right rear in heavy loads but thats cause i got to fix a problem. 215 will look too bulgy on 6.5 rims.... good luck
Old Nov 15, 2005 | 10:20 PM
FalkenSiR's Avatar
Default Re: (TsukubaDreams)
don't they have them in 15x7s too?
Old Nov 15, 2005 | 10:33 PM
DriftTheEg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TsukubaDreams &raquo;</TD></TR><TR><TD CLASS="quote">im runnin the same size rims.... i wouldnt go bigger than a 205/50/15. No rubbing upfront and only just a lil in the right rear in heavy loads but thats cause i got to fix a problem. 215 will look too bulgy on 6.5 rims.... good luck</TD></TR></TABLE>
Same with me. I have 15X6.5, anything bigger then a 205/50R15 WILL rub if the car is lowered at all. If your ridind stoke height, theres a chance you might not rub at all. I went through that problem. but luckly i was able to test fit to see what would fit best. I would recomend the Dunlop Direzia. Bad *** tire
Old Nov 16, 2005 | 04:49 AM
ZacCarter's Avatar
Default Re: Widest tires on a 15" rota (ADN_pt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ADN_pt &raquo;</TD></TR><TR><TD CLASS="quote">Eu estou a comprar jante de 6.5 ROTA para poder usar 195 na sua capacidade total e tu a fazer o contrario. 6.5 é para 195 ou 205 para estar idealmente adequado.</TD></TR></TABLE>
English please. I run 205s on my civic, its lowered on omnis, not to much rubage.
Old Nov 16, 2005 | 04:59 AM
94hatchling's Avatar
Default Re: Widest tires on a 15" rota (ZacCarter)
i'm running 205/50s on my 15x6.5, and i rub. not in a straight line, but under any turning i rub. but then again, i also have no sway bars, so that might cause the problem. but yeah, i wouldnt go any bigger than 205s.
Old Nov 16, 2005 | 05:16 AM
The_Head's Avatar
I'm have a set of 225/50 Drag Radials mounted on my set of Rota's, But I dont know their offset. The car is at stock ride height, and they did not rub for me.
Old Nov 16, 2005 | 12:43 PM
bmoua's Avatar
i have falkens 205/50/15 are they are prefect..woudn't go any bigger
EK9Tune
10
Dec 2, 2007 11:18 PM
Change Me
Honda Civic (2001 - 2005)
Apr 14, 2007 07:16 PM
Erod
50
Sep 9, 2004 05:03 PM
wizzards581
11
Apr 20, 2003 11:45 PM
zither
Jun 22, 2002 08:14 AM
